Results 1 to 7 of 7
    Jack Evers's Avatar
    Jack Evers is offline Car Fool
    Nov 2006
    Phoenix
    Engine Malfunction Code
    Had a nice time at the Havana Cafe. Great to meet some of you guys that I missed at G.A.M.E.
    Sorry to bother you guys with questions about the Engine Malfunction Code my car is displaying. When I got home I checked the forum and came up with the correct key dance sequence. Turn to "on" position, then to "ACC" position, back on "on" rapidly three or four times quickly.
    I came up with a P0128 code which is "Thermostat Rationality." It has to do with the 170 degree stat I installed. Tomorrow, out comes the 170 and in goes a 180 or 190 degree replacement. We'll see if that does it.
    Jack Evers
    Phoenix, Arizona
    06 300C SRT-8
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Or let it warm up a bit before you take off... that seems to work with mine so far.
    Jack Evers's Avatar
    Nov 2006
    Phoenix
    Quote Originally Posted by GasGunR View Post
    I don't sit in my driveway until the coolant temperture is 180 degrees but I do warm it up some.
    Both times I've had this light, the ambient temperature has been pretty warm. Today it was 95 degrees. The system takes ambient temperature into consideration and after 10 minutes of driving, it was saying to itself:
    "Hey, it's ninety five degrees out, this idiot has been driving for 10 minutes now and I should be at 180+ degrees, but I'm not. Better throw a light"
    I have to conclude that the hotter it is outside (higher ambient temperature) the quicker and more often we'll be getting the P0128 code.
    Jack Evers
    Phoenix, Arizona
    06 300C SRT-8
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Glad I don't live in Gila Bend then anymore
    Hope you get it corrected!
    Don
    carchitect's Avatar
    carchitect is offline has been pardoned by the language filter
    Morton Grove, IL
    Quote Originally Posted by Jack Evers View Post
    Sounds like you need to talk some sense into it...
    Sounds like she may not be heating up enough, the 180 or 190 t-stat should do you good.
    joeb1's Avatar
    joeb1 is offline Old Geezer
    Glendale, AZ
    Don
    Doncha miss it even a little?
    Joe B Glendale, AZ
    Arizona LX Club Member
    Magnum Owners Club Southwest Chapter Member # 1015
    2005 Magnum RT Inferno Red Tinted Pearl Coat
    Joe B Glendale, AZ
    Arizona LX Crew Member
    2011 Charger RT MAX
    Redline 3-Coat Pearl Black/Radar Red interior
    LIGHT 'EM UP!
    ICLOSEM's Avatar
    ICLOSEM is offline Ebony & Ivory
    Jan 2007
    GLENDALE,AZ
    i just installed mine on saturday and havent had a problem yet i figured we are in az the cooler the better.. glad to hear you got it figured out
