Results 1 to 10 of 10
    Fast56k's Avatar
    Fast56k is offline I ain't no FRI baby!!!
    Mar 2006
    Anyone got any 8x8x16 concrete block?
    I am looking for like 100 to do a retaining wall.
    C.
    Silver 06 CSRT-8
    carchitect's Avatar
    carchitect is offline has been pardoned by the language filter
    Morton Grove, IL
    that particular size of CMU block comes about 100/pallet. Home depot/lowes, or any builders yard should be able to drop them off for ya.
    Are you building an actual retaining wall (to hold dirt back) or just something low and cosmetic?
    2006 Inferno Red Charger R/T|Zoomers|C&L Intake|Retro Mag 500 Wheels|Pedders Touring Plus w/ adjustable camber|General Grabber UHP 255/55/18|Flat Black Daytona Grille|BT Catch Can|SRT-8 Rear Diffuser|Mopar Chin Spoiler
    Fast56k's Avatar
    Mar 2006
    Quote Originally Posted by carchitect View Post
    Yea. It is a retaining wall to hold back dirt.
    C.
    Silver 06 CSRT-8
    carchitect's Avatar
    Morton Grove, IL
    Quote Originally Posted by Fast56k View Post
    C.
    I don't know what you do for living, my questions are meant to help you and keep you from having to do this again.
    How tall you looking to go? At the top of the wall will grade remain level or slope upwards?
    Depending on height you may need to go to concrete, and even then I'm not sure I've ever seen a modern retaining wall made out of the cmu I think you are trying to use. If it's low enough with level grade you could try that split face block with the lip on the backside. Are you planning on a concrete footing with continuous rebar through the block as well as grouting the block solid?
    stroguy's Avatar
    stroguy is offline 07 Charger RT R&T
    Oct 2005
    Spring TX
    Sounds like I need your input also carc.
    2007 Road&Track Charger
    Billet Technology*AMG paddles*AFE II*Jina SSE
    Eibach&Koni*FR wheels*SRT8 hood #993*Predator
    Danko*Hurst paint & body*Wings West
    lethal300c's Avatar
    lethal300c is offline 300C Lover
    Sep 2008
    Lexington, KY
    Another thing...unless I am mistaken, most standards were changed a number of years ago to a limit of 2' high. Anything above that might require engineering. Make sure you are up to speed with your local codes. Pain the the arse I know, and better safe then sorry.
    Keith
    PPP Stage III Heads/Cam * K&N CAI * ARH Long Tubes w/High Flow Cats * Borla Aggressive 125 Exhaust w/5" Tips * DMH Low Profile Cutouts * Zex Nitrous * Precision Industries 3,600 TC * Level III Tranny Upgrade with Paramount Stage II Vavle Body * Diablosport w/CMR Tune * Black LED Tails * TIS03 22" Wheels * Many more
    Fast56k's Avatar
    Mar 2006
    Have 3000 psi footing with rebar. It is a two foot (3 blocks hight) wall with a level slope. I am filling the middle of the block with concrete as well.
    C.
    Silver 06 CSRT-8
    carchitect's Avatar
    Morton Grove, IL
    C.
    Sounds like you are good to go! I'll get out of your way
    Fast56k's Avatar
    Mar 2006
    I appreciate ya lookin out for your fellow lx'r.
    C.
    Silver 06 CSRT-8
    stroguy's Avatar
    Oct 2005
    Spring TX
    You can get in my way carc.
    I want to build this in my backyard.
