Page 1 of 3 123 LastLast
Results 1 to 15 of 40
    Daytona Crazy's Avatar
    Daytona Crazy is offline CraZy LX'er
    Nov 2007
    Ft. Lauderdale
    First Time Down the Track!!!!
    All I can say is WOW!!! Tonight was my first time down the drag strip and it was AWESOME!!! First run I took it easy just to get the feel for my car and the track. Then I started to let loose.
    First run= r/t: .551 1/4: 15.430 @ 82.28mph
    Second run= r/t: .145 1/4: 14.659 @ 94.36mph
    Third run= r/t: .666 1/4: 14.28 @ 99.09mph
    Thanks GoManGo (Chuck?) for helping me out with all the tips and pointers. I had a great time and I can't wait to do it again.
    I will see some of you on Sat.!!!!!
    sig by Elcobra44
    formerly owned PlumCrazy #547
    PowerWagon896's Avatar
    PowerWagon896 is offline Clever Disguise as a Responsible Adult
    May 2006
    Waiting on the gravy train
    Quote Originally Posted by Daytona Crazy View Post
    14.28 @ 99 MPH is a pretty respectable run for a stock R/T.
    Get rid of some excess weight, (spare, jack, etc) pump the front tires up to 55 PSI, lower the rears to 26 PSI W/the gas warnig light on & you'll be in the 13s if you can still get it "hooked up".
    A 180* TSTAT & the "25 cent fan mod" won't hurt either.
    Oh yeah. Try leaving on the last yellow, don't wait for the green.
    That will get your RTs down.
    LitiGATOR's Avatar
    LitiGATOR is offline LX Padiwan
    I just got back from Moroso and saw some fellow LX'ers there. I know rtr0id turned at least a 12.9 in his 300C-SRT8. He was telling me that there was a silver Charger SRT8 that ran ~12.6, with intake and Diablo Tune. Same mods rtr0id and I have . . .
    For me, I ran a 13.1 with a .008 rt. I couldn't hook up well, and thought for sure I'd get in the 12's tonight, with the temps hovering right at 40 degrees. I lowered the psi in the rears to 25, and the front were around 28. Maybe I should add some pressure to the fronts? I couldn't get below a 2.15 60' time. But the 13.1 was my best run so far, and I'm getting closer and closer to the elusive 12.999 that I'm striving for.
    jpilone's Avatar
    jpilone is offline Dog Bites Hurt!
    Delray Beach, Florida
    Sorry guys, it was just too damn cold for me to come!!
    -Jarrod "Super G" Pilone 12.956@108.14
    http://www.moparsofthepalmbeaches.co.../v/convertible
    Nov 2007
    Ft. Lauderdale
    I thought I was leaving on the yellow. But I don't think I did too bad for my first time out....ever. I didn't want to mess with the tire pressure or anything just yet. I am going to have my hubbie make that fan mod for me. Chuck showed it to me last night. I can not wait to get out there again. I want to try and work on my RTs next trip. Thanks everyone for the support, I still felt very welcome, even though I didn't get to see any of you. It's a bit Intimidating being one a the very few females out there. But rest assured I will see you there for the challenge!
    sig by Elcobra44
    robsrt's Avatar
    robsrt is online now SpeedRated Motorsports
    Fort Pierce, FL
    Congrats on the times. That's very impressive for the first time out.
    I made about five passes and left around 8. I made two passes of 12.76 back to back. After that, I couldn't hook. Even if I eased it off the line, I would spin through second gear. I was hoping for a personal best, but the traction just wasn't there. I think it was getting worse as the night went on.
    RIP Lou
    CplDaugherty's Avatar
    CplDaugherty is offline Once a Corporal... Still a MARINE.
    Dec 2006
    Back in Indiana
    Great job for your first time!!! Took me till about my 20th run down the strip before I started getting better RTs (.1 and lower... even cut a .001 about 6 weeks ago!). Your times will get better as you learn some of the tricks and get to know your car better.
    Adding pressure to your front tires will def help LitiGATOR. Less of your front tires touching the track will decrease the resistance from them. And lowering the pressure in your rears helps you get better traction.
    If you can read this, thank a Teacher.
    If you can read this in English, thank a MARINE.
    Sponsored by Billet Technology
    Powered by Franks Racing Inc
    New build: 392 stroker, FRI street/strip heads, FRI cam, Kooks Longtubes, PI 3400 TC, SLP LM2 catback, LMI CAI, 09 Intake, CTP port matched spacers and DS loop, MTCM, Ported TB, BCR Coilovers, R1 rotors, Autometer AFR and fuel pressure gauge, Motorad 176* tstat, SRT wheels, carputer.
    [06 300C - 70 Mach1 347 stroker - 77 F250 460 - 85 Ramcharger 318]
    "I spent a lot of my money on booze, women and fast cars. The rest I just squandered."
    Crazy8's Avatar
    Crazy8 is offline Plum Crazy # 981
    Aug 2007
    Lake Worth, FL
    Playing with tire pressure definitely helps. I run my Daytona with 40psi front and 20-22psi rear. With cat back, CAI and the 8R14 Diablo tune, I am at 14.06. That is with spare, jack, full tank of gas, etc. If I were to shed some lbs, I'd be in the 13's. I think this Spring, Long Tubes, Torque Convertor and possibly Nitrous might be on order for my Daytona.
    Congrats on the great runs!! Your reaction time will steadily improve! In my Z06, my reaction time was always .300 to .500....in the Daytona, it is a lot better (might be that the autos are easier to launch than a 6 speed...and the Z06 was famous for the bog when you launch).
    2008 Chevrolet Corvette - 3LT, Z51, U3U, NPP, MX0, 418ci LS3, 3600 Stall Converter, and more. 10.9 in 1/4 on oversized drag radials
    2007 Charger Daytona R/T # 981 PC - Corsa Catback, Mopar Intake, Predator Tune,
    http://www.motortopia.com/cars/7573
    FLXC Member 5.7L Hemi Registry # 00748
    2007 GMC Yukon XL- Daily Driver and tow vehicle
    1986 Chevrolet Monte Carlo SS - going to body shop soon for paint
    R/Tdrvr's Avatar
    R/Tdrvr is offline "If at first you don't succeed, reload!"
    Jun 2007
    South FL
    How big was the grin on your face after that first run? I remember my first run (after I said I was just going to watch) I couln't stop smiling. Its nice to go WOT without having to worry about a set of blue lights flashing behind you.
    The only thing worse than a zombie chasing you, is a zombie that's on fire chasing you.
    2007 Charger R/T, Brilliant Black Crystal Pearl, AFE Stage 2 CAI, SRT headers and mids, Flowmaster Super 44s, 180 T-Stat, Tails by Charg-um, Diablo tuned, 5.7L HEMI Registry# 00736Best 1/4 mile: 13.70 @100.47mph.
    rtr0id's Avatar
    rtr0id is online now LX Guru
    Apr 2006
    Congrats!! you improved with every pass, way to go.
    The best i could muster last night was a 12.97. Couldnt hook up. Cold track = no traction. My 60fts got worse on each run. My last 2 were 2.4s :(
    I think last night was one of the busiest I've seen Moroso on a test an tune night.
    btw i normally have wire an connectors to make the .25 cent fan with me at the track
    LitiGATOR's Avatar
    Quote Originally Posted by CplDaugherty View Post
    Thanks! I knew that lowering the rears would help with traction -- so I did. But I didn't know that inflating the fronts would make a difference. I think next time I go, I'm going to go down to 23 psi on the rears and 40 psi on the front. I HAVE to get that 12.999!!
    nhdave's Avatar
    nhdave is offline This space for rent.
    New Hampshire
    Quote Originally Posted by LitiGATOR View Post
    The more pressure, the harder the tire, the less roll resistance you get.
    Every little bit counts..
    06 Inferno Red Magnum SRT8
    Pretty stuff: Blinker mod, Silverstars, Auto Headlight, ERF Backups, 22Elite console w/Jina's stitching
    Go-fast stuff:
    Arrington 426 w/607 cam and FRI Heads by BFNY Performance, Tuned by HemiTuner, Kooks, Protorque 2800, Airhammer, 180 t-stat, Cool-It, B&B Catback
    11.973@112.45 N/A
    11.42@117 - 1.579 60'
    juiced
    Blondie's Avatar
    Blondie is offline Bite Me Dough Boy..
    West Palm Beach FL
    Congrats and you have definetly inspired me!!!! I was intimidated but I think the next time I am going to show up and have the guys give me some pointers and give it a try.
    FLXC MEMBER
    Hemi Registry # 00664
    TorRed Daytona # 801
    AIRHAMMER CAI, Painted Calipers/Decals, Mopar hood struts, Air diffuser,BT door sills,shifter and RED oil catch can, Custom 22 elite console cover and Custom Daytona floor Matts, Sequential turn lights and Blinker Mod
    Airbrushed engine cover,ABS, fuse Box and Coolant tank..
    Resonator Delete..
    Custom Daytona Trunk lid cover
    More to come!!!!!
    Nov 2007
    Ft. Lauderdale
    Quote Originally Posted by Blondie View Post
    These guys are really cool and friendly. It is alot of fun and it would be cool to have another female out there to team up with. You should try to make it to the Mopar Challenge get together this Saturday. The first official race is the 19th so I have more practicing to do. I will PM you the next time I decide to head that way.
    sig by Elcobra44
    Dec 2006
    Back in Indiana
    When I ran my 12.9 on street tires I think I was at 48 or 50psi on the fronts and I wanna say 22 or 24psi on the rears... These were on the stock 18" wheels on my C, yours may be different since you have a SRT... but raising the fronts will help. Just make sure you get a good burnout so the tires will be hotter and stick better. If you're that close I'm sure you can get it.
