Results 1 to 1 of 1
    DragonSlayer's Avatar
    DragonSlayer is offline DRAGON SLAYER
    Home of the Gators!!!!
    Dei Viper Alarm System With Remote Start For Magnum
    My best friend gave my a Viper 791xv Alarm system with Remote Start. WHAT A FRIEND!!! Anyway did have to buy an accessory piece to with it in order for it to work with the Magnum. It is called Peripheral
    http://www.peripheralelectronics.com/
    By using this piece you DO NOT need an extra key and don't have to use one of the two you have. The module number you need for the magnum is XK532
    Select the make, model, year Then click on xk532 to get more details
    http://www.xpresskit.com/index.aspx
    http://www.xpresskit.com/getdocument...documentid=678
    They refer to the Skim Module this is located behind the radio on the left. You must take out the Radio.
    By using the peripheral you DO NOT have to use any resisters. Just make sure you have some connectors.
    This is a pretty intense install if you don't know what you are doing my B/F use to install DEI Alarms so was a bit easier for him but this was a new module that he did not use before.
    Hope this helps I could not find anything on here that told where the Skim Module was or what to use.
    P.S. I do get the RKE Battery Low warning popping up I have already replaced my batteries. But the Alarms and Valet Start works GREAT!!!!
    Mods: MoPower Front Spoiler, RamAir Hood, DUB Cold Air Intake, Jet Stage 2 Module, JBA Cat Back Exhaust, Vredestein Sessanta Tyres, Molding Removed, No Rear Wiper, No Pin Striping, 180 Thermostat, Police Flash, SuperChip, Stronger Stainless Hatch Struts w/Remote Release, DEI Alarm w/Valet Start, Stainless Hood Struts, Dragon Eye Custom Art Work, EBC Yellow Stuff Brake Pads, EBC Dimpled and Slotted Rotors,
