Results 1 to 4 of 4
    Biged83's Avatar
    Biged83 is offline LX Guru
    Jul 2009
    Daytona Beach, FL
    XXL HJC crypt helmet
    This is a new in box helmet. I only had it out of the box to change the front screen to a smoked one. I will include the clear one with it. Looking to get 150$ for all of it2008_HJC_CL-15_Crypt_Helmet.jpghelmets-hjc-street-2008-men-cl-15-crypt.jpg
    2012 Fiat 500 Sport
    Meech's Avatar
    Meech is online now LX Guru
    Nov 2006
    What is the "SA" Rating of this helmet? SA2005 or SA2010?
    Interested. PM sent
    Chubby Pro Sways, BCR Coil Overs, Jay's Camber Arms,Speedlogix Bump steer kit/Wretched-Pedders Lower Control Arms BlueTops/CL63 Rear Cooler/JoelVan Rad/PS Cooler/PO Cooler/SRT Max Plus Cam/Forged Push Rods/600HP Half Shafts/Magnaflow Hiflow Cats, Corsa Cat back/ Staggered Satin Vipers wrapped in Vredestein Ultrac Sessantas 275/40/20's (front) & 315/35/20 (rear). HHP Installed Wavetrac/NASCAR Cooling Ducts to ET1970 3" Brake Plates/TI (Track) Backing Plates/ AERO Hood/Naturally Aspirated Force Flow Legmaker CF-F-III STU-HHP Modified HemiTuner DynoTune:
    Diablo 93 Octane 433 RWHP/425 RWTQ
    Meech's Avatar
    Nov 2006
    Never mind, just realized this is a Motorcycle helmet, cannot use it I drive fast things with fenders.
    Biged83's Avatar
    Jul 2009
    Daytona Beach, FL
    • HJC CL-15 Helmets feature injection-molded, polycarbonate composite shell construction
    • Two-piece channeled dual-density lightweight EPS liner
    • Large eye port opening for greater visibility
    • Unique CAD generated shell sculpture for exceptional fit and increased helmet stability
    • Flow-Through "ACVS" Advanced Channeling Ventilation System
    • Two multi-stage forward intake vents and a large integrated rear exhaust spoiler are combined with sculptured air channels allow the entire helmet to act as a full venturi exhaust system; fresh air is channeled front to back, drawing heat and humidity up and out of the shell through four internal exhaust channels
    • Side chin bar venturi exhaust vents for increased heat and humidity dissipation, easy to remove Nylex® liner and cheek pads for cleaning and air drying, sculptured wrap-around neck roll reduces wind noise
    • Padded chin strap design
    • 3rd Generation 2-Stage Pivot/Compression Shield Closure System
    • HJ-09 anti-fog and scratch resistant hard-coated shield
    • 3rd generation easy function tool-less shield removal system
    • Advanced, 2-stage shield pivot/compression system ensuring maximum shield seal
    • Aerodynamic flush-mounted fit for reduced turbulence noise
    • Scratch-resistant hard coated shield with optically-correct 3D design
    • Shield radiation protection capacity rated to block 95% of harmful UV radiation
    • Soft helmet storage bag included
    • DOT-218 and SNELL-M2005 approved
