is there anywhere i can find those instructions? 6.1 magnum... i came across a used one, installed it... but then i saw a picture of a couple other cars... and mine does not match. i get ALOT of oil though...
2006 Bright Silver Magnum SRT-8
Air Hammer CAI - AirAid TB Spacer - Diablotoona Equiped
NGK Iridium Plugs - Magnaflow 3 inch pipes
BT Catch Can - LED signal lights
Pioneer Avic Z110BT Hacked and Bypassed
Factory HID Conversion - Flashtech LED Halos
They are available right on our website in the product description... Thanks..
on the 6.1, i saw a picture where the hoses ran from the upper nipple, just behind the tb, and from somewhere behind all the coil wiring. do these have rear pcv valves too?
Just in the front. Not sure what you are referring too.
if i can find that picture again ill post it up.
Im having a hard time understanding what your issue might be. There are only two places for the Cans hoses to go on a 6.1, One is just above the T/B and one just below.
Thanks
Your last reply is what i was wondering. thats how i have it hooked up. i was looking around at some pictures and saw how someone else had theirs set up, i think they were running the PCV in then back to the oil filler air breather... were the filtered air goes into prior to the TB. i only asked for the instructions because 1. i bought it second hand, 2. i saw someone elses setup, which might be incorrect, and 3. im still getting the puddle of oil in the intake.
Im still confused. Maybe you were not looking at a 6.1? Or looking at a car with a blower. Im not sure which bracket you are using but all a catch can is ,Is basically a filter between the inlet and outlet of the PCV system.
THanks
