Results 1 to 15 of 18
    gnat is offline LX Newbie
    Apr 2006
    Austin, TX
    HELP, my car is on jack stands
    I attempted to swap out to an SRT suspension today but we couldn't break loose the ball joints. I got a pickle fork from Autozone but it isn't big enough to split the ball joint. Does anyone in the Austin area have a larger pickle fork?
    I got things apart but now I can't put anything back together. My car is out front on stands with the wheels off.
    Please can anyone help?
    cbloveday's Avatar
    cbloveday is offline My Friends Call Me "C Love"
    Jul 2007
    Reminds me of the time, my little one got coins stuck in the all on one tv/cd player and I took it apart and then couldn't put it back together. Sucks
    2006 300C SRT8 Silver *SOLD*
    BES P&P Heads,BES Intake,K&N CAI,BES CAM, Kooks LT CC Headers,HiFlo Cats,2800 TC
    ,Magnaflow Catbacks,Brembo CD Rotors, Braided Lines,Hotchkis Sways,DC Strutbar,BT Catch Can,Vellano VSY Rims,Mopar Chrome,Mopar Grill,,K40 radar,SRT8 Illum Sills, Dyno Steve Tune,
    LM-1,Alarm/Starter
    2007 Escalade ESV Black Raven
    2007 BMW M6 Black Sapphire Metallic
    Super T's Avatar
    Aurora, IL
    autozone rents tools, you get the money back when you return the tool...
    Apr 2006
    Austin, TX
    I rented a pickle fork and a pitman arm puller from Autozone. the pickle fork didn't work and the puller looked like someone had shaved the arms back and it wouldn't fit.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Screw the pickle fork.....that'll just mess up the boot.......put a jack just under the control arm so there is about a 1/4" space......loosen the ball joint nut almost all the way off...keep it on a few threads....Now get a 5lb hammer and smack that flat spot on the spindle as hard as you can.....a few shots and the joint will pop out of the spindle.....then just remove the nut and lower the jack.
    BFNY PERFORMANCE
    RIP My Friend
    Apr 2006
    Austin, TX
    is it the flat spot on the front of the spindle?
    Hemi31's Avatar
    right where the ball joint stud goes through......that flat spot.
    BFNY PERFORMANCE
    RIP My Friend
    Apr 2006
    Austin, TX
    too dark tonight, I'll try that tomorrow morning.
    Apache's Avatar
    Apache is offline LX Padiwan
    May 2005
    Temple, TX
    Just be carefull when you lower the jack, SLOW is the key, the spring may pop and can go anywhere. For safety reasons, may want to put a strap/chain or something to secure the coil before you lower that jack. I just did this with my 64 GMC truck. As Hemi31 said, the pickle fork will or may damage your rubber boot, but if you are replacing it, then don't worry about it. Good luck and if you need more help, post back up.
    Mike
    2005 Midnight Pearl Blue RT
    ephines's Avatar
    ephines is online now Looking for something new.
    Mar 2006
    Bremerton, Wash.
    If you got a good tie down strap or rope you could pull the spindle and arm down just enough to pull the bottom of the shock out.
    You need to leave the rear most nut on top loose(like two turns left) and you would put a knee in the strap that you have attached to the top of the A-arm (holes on the side of the ball joint). The whole assembly needs to go down about a half an inch to pull the bottom of the shock out towards the rear with the wheels straight. You will need some muscle but much. I've done 4 magnums this way with no problems.
    Coors Light Silver 2005 Magnum RT
    MODs MyGig-Nav, 22Elite console cover, Leather door pulls, 10" Alpine Type E Sub in a ME Design enclosure w/ Alphasonik Amp, 3M Invisi-bra, Mopar CAI, 09 replica Challenger Wheels, Mopar Lowering Springs/Eibach Shock Hotchkis Sway suspension.
    Apr 2006
    Austin, TX
    I had someone standing on the brake rotor and we still couldn't get enough room to get the bottom of the shock out.
    I either need to separate the ball joint of find a way to compress the strut a little.
    Apache's Avatar
    May 2005
    Temple, TX
    What about spring compressors? You can borrow those from Autozone as well or Harbor Frieght tools has them as well as a larger pickle fork. Good luck.
    Apr 2006
    Austin, TX
    smacking the spindle worked. I never would have thought of that. so after all of this I still don't have the suspension swapped. but at least now I know how not to do it. I am going to wait till later to attempt this again.
    gameover's Avatar
    gameover is offline voiding warranties
    May 2006
    New Orleans
    I use this and it works like a charm. Could be rented or bought at Autozone.
    05 RT . Jett Black . SRT Fascias . UAS . AFEII . Zoomers . Forgiatos . Wilwoods ...
    flossin22s's Avatar
    flossin22s is offline LX Padiwan
    Jul 2007
    Fresno,Califas
    Quote Originally Posted by numbasyx View Post
    YES!!!! these things take it off in a minute.....i used it on mine and my buddies
