Results 1 to 15 of 19
Thread: Start Button ?
    dewm1's Avatar
    dewm1 is offline Save time, see things my way!
    Nov 2005
    Airdrie Alberta
    Start Button ?
    Howdy folks,,, has anyone installed a Start button?,, I think they come out in the Vipers, SRT10's and such. Is there a how to anywhere?.
    I searched but had no luck with my search terms, or it came back with 11 pages,,, if we could do a search by start AND button,,,
    Sorry, wrong forum, noticed after.
    David.
    '05 300LTD Dark Lava Red.
    http://dewm1s300.shutterfly.com/
    Super T's Avatar
    Aurora, IL
    Nope. Problem is the car needs to see the actual key for the SKREEM system. Once it's in the ignition for that, why not just turn it??? If you could completely bypass the SKREEM then it'd be a very simple mod (just two wires out of the ignition switch).
    dewm1's Avatar
    Nov 2005
    Airdrie Alberta
    Well, that makes me wanna SCREAM,,, .
    So the key would still be in the ignition, I don't mind. I could install the start button somewhere, console, dash, wherever I wanted, and push da button?,, just 2 wires?, nobodies done this?, hmmmm, sounds like a why not do it?.
    "why not just turn it?",,, why do I want a START button, why not?, why did they put them in the Vipers, SRT10's and such? Looks cool, functionality enhancement?, nope.
    David.
    MattRobertson's Avatar
    Feb 2005
    At the bus stop...
    There's a way to dummy this up without the key... Buy the Mopar remote start unit and put a button on the dash. You'll have to push it twice but that'd work.
    Of course, its a lot more fun to be able to start the car from a distance so if it were me (and I did this) I'd just take the remote start, put it on my keychain and NEVER use the key (or Start button) ever.
    Super T's Avatar
    Aurora, IL
    I'm with ya, I'd like to see one but I'd want it in conjunction with a smart key system that unlocked the doors and allowed the car to be turned on just by having the car inside. **sews mouth shut** But yeah, the ignition has five wires...
    2 that are the SKREEM "key sense" circuit, one that is constant fused power, one to turn the car "on" (a.k.a. Accesory, run, whatever), and one for start. So you'd have to grab +12V from somewhere and run that to your new button switch, then from the other lead on the switch run back to that fifth "start" wire. As long as it was a momentary switch you should be fine, unless maybe you had to add a resistor like you do for the hatch popper on the magnum. but you'd still need the key in the ignition so the car knew it was legit, and you'd still have to turn the key one click to the "on" position. I guess if you really wanted to, you could use a SPST toggle switch or something to perform that function as well. Then you'd just throw your key in the slot, flip a toggle, and push a button. Seems like a lotta work for a button :-P
    What I'd like to see is a SKREEM bypass, like some alarms use, that can be operated off of a switch. But for that switch I would want to have a 10-button keypad a la the Transporter. It's so simple in theory, but so damn hard to create apparently.
    Quote Originally Posted by dewm1 View Post
    colsar's Avatar
    colsar is offline Mopar Fan
    Aug 2007
    Knox Area, TN
    I'm with ya, I'd like to see one but I'd want it in conjunction with a smart key system that unlocked the doors and allowed the car to be turned on just by having the car inside. ...snip....
    That sounds like a Nissan!!
    Joe.
    2007 Chrysler 300C Silver Steel. (also; 2004 Chrysler Pacifia awd, 2003 Dodge Ram 2500 V10, 2003 Suzuki Volusia.)
    Past Mopars: 1969 Dodge D100, 1987 Dodge Shadow, 1966 Plymouth Barracuda, 1978 Dodge D100, 1991 Dodge Spirit, 1994 Jeep Wrangler, 1996 Dodge Ram, 1955 Plymouth Belvedere, 1967 Plymouth Satellite, 2003 Dodge Ram 2500 Hemi, 2004 Dodge Neon.
    Super T's Avatar
    Aurora, IL
    You mean 3M the remote to the dash, right? The remote start brain doesn't have an input for any kind of switch. I wonder if you could trick it into being in a perpetual state of "run" (the remote start brain, that is) so that it used its SKREEM antenna to lie to the car about the key while you drove.
    Quote Originally Posted by colsar View Post
    That's what I was referring to... for now...
    BLUE-MIDNIGHT's Avatar
    BLUE-MIDNIGHT is offline LX Newbie
    OK from gathering 2 things i know about you 1 your quote below your username and 2 this knowledge that you just displayed. I came to the conclusion that ill never let you know where i park my car LOL
    Super T's Avatar
    Aurora, IL
    Naw dude, I wouldn't know where to start w/ stealing one. If I could figure it out, I'd have the keypad installed already :-P
    Feb 2005
    At the bus stop...
    No, I figure someone is smart enough to fab something up so you have a button on the dash... you'd just have to press it twice.
    sax911's Avatar
    sax911 is offline Just bought mine!!! 07' 300c SRT-8
    Jan 2008
    KC
    I would set the car up with remote start and use a second remote inside as a start button even disassemble it and make it look like a high end start button...
    bigal470 is offline LX Guru
    Nov 2006
    Oceanside, ca
    how about a nice button like this
    timdebjake's Avatar
    timdebjake is offline LX Padiwan
    Nov 2004
    Fairbanks, Alaska
    If i remember correctly, and i may be wrong dont have my car or manual with me in Korea, i think my viper 791xv has a wire i can ground to start the car. If that is the case i could put a button in and just have it go to ground, but still have to put key in.
    yubyub is offline Re-member
    Brooklyn, NY
    There are two things here, IIRC, to make stuff work:
    a) the RFID in the fob needs to be close enough to make the ECM think there is a valid key in the ignition. You can get RFID chips that you can program to the ECM (i.e. a chip separate from a key) - the issue is one of range. If you bolt it in to your dash, then you've removed all of the security features that you get from having a chipped key in the first place.
    b) you still need something to do the "off/acc/on" positions of the key. Adding a pushbutton start is easy after that.
    Does anyone have the schematics or logical flow of how it works in a pushbutton start vehicle? If so, we can reverse engineer quickly and easily.
    I'd love a larger proximity on my chipped key and a start button...
    (I have a moderate background in EE, so electronics is easy enough to figure out once we have the proper info).
    Meathammer's Avatar
    Meathammer is online now Ugh, kittens give Morbo gas
    Mar 2006
    Mid-West Michigan
    Quote Originally Posted by yubyub View Post
    I'm wondering is something like a fingerprint reader could be set up to either of those functions. Yeah it's involved, but unless somebody had your finger, it would be good security. I would think that using something like that would be best suited to handle item "a)" simply as it could also be used as your "key" to unlock the car. Replace the keyhole with a fingerprint scanner.
    Just dreaming.....
    The "Un"Club!
    We have two rules, Love Cars and Have Fun!
    Michigan Charter Founder
    2005 Inferno Red (PEL) Magnum R/T - Hemi Registry #000573
    - Todd -
