A large number of new CAI’s that have been released since the last MOFO. As part of the ongoing discussion of the pro’s and con’s of all of these new gadgets, much discussion has happened regarding the resistance to heat transfer of underhood heat to the intake air stream.
We see many variations of design intended to thwart heat transfer and have heard many opinions about the validity of each design. As a pioneer of measuring temperatures in the intake (December of 04) and an addicted drag racer, I suggested to CV and Matt that we test heat resistance this year.
Naturally, they volunteered me to head this testing up. Now I cannot make it to MOFO this year, so I immediately recruited more volunteers among the group that will actually be in attendance.
Junior – Wrench, driver and donor car. The testing will be conducted on his Charger Daytona. The key mods that are important to this test are a 180* thermostat, GSM Fan mod and the removal of the lower left radiator baffle.
Mosie – Predator Operator, Computer Operator and data compiler/reporter.
Here is the preliminary protocol for the test.
The test sequence will travel a fixed course on each run. The Predator will be connected and logging Ambient, ACT, ECT and MPH:
1. Using car with 180* thermostat and fan controller that will run both fans), warm to 180* ECT and install CAI.
2. Measure temperature on throttle body to set a consistent staring temp. Cool down or run engine as necessary to obtain temperature. This step is important to account for the radiated heat from a warm engine.
3. Start engine, begin log and close hood and idle with fans on for 7 minutes and log temperatures for each minute. This test simulates waiting in staging lanes at a drag strip.
4. Immediate drive X distance at 30 mph and log temps each minute for x miles. The x miles will depend upon the course that Mosie and Junior choose for the runs but will be about 5 miles. This test simulates city driving.
5. Stop and bake at idle for 3 minutes and log temps.
6. WOT 0- 70 mph and hold at 65 mph for X miles. Measure temp drop over first 10 seconds, 30 seconds and 1 minute and at minute increments afterwards to see how fast the temperature drops to a minimum constant value at constant speed. The X miles will depend on the course chosen but will be the same for all tests.
The Procedure is really simple. Run the test procedure with each intake while logging the entire run through the Predator. Then dump the logs to a .CSV file and into Excel. Then publish the values(Ambient, ACT, ECT, MPH) along a timeline of 1 minute intervals, broken into segments that show idle, low speed, high speed.
This protocol is open for discussion and comment. Please be specific in your comments.
