Last updated April 13, 2008
Q: Generally speaking, how can the Mods Face Off Results sometimes be so different than results released by manufacturers?
The Mods Face Off events are not trying to prove or disprove manufacturers' claims with regard to the results of their products. Rather, our whole goal is to show what can be expected, on any given average day, when you stomp on the gas. Our testing methodology, in fact, directly reflects this goal:
This point cannot be overstated: the Mods Face Off philosophy is simple. We attempt to answer the question "What can I expect from my daily driver when I stomp the gas?" Our tests are specifically (and uniquely) tailored to answer that exact question. Our tests simply will NOT yield what any given mod, under ideal conditions is capable of. The manufacturers tests will provide that information. Comparing the two is really akin to comparing apples to oranges. You owe it to yourself to consider both sets of results when deciding where to spend your modding dollar.
- We standardized on 2 gear pulls as that is how our LX's naturally want to run. The industry standard is to make a single gear pull.
- The Mopar TCM and CMR tuning has now allowed for single gear pulls. When possible, we try to use these in order to get those single gear pulls as that has proven to be what most folks want to see. This is taken on a car by car basis, but will always remain consistent for a given test.
- We'll fill up at the local gas pump where octane rating can legally vary plus/minus 3 from the advertised rating. The industry standard is to ensure a specific octane while testing.
- We use inertia mode on the dyno. The industry standard is to test in loaded mode.
- We make no attempt to control our climate; except to keep that environment as consistent as possible when deriving relative results on test day (our variables will not vary between tests). The industry standard is to regulate temperature, pressure and humidity for testing.
- We publish numbers averaged between three consecutive pulls as "official" Mods Face Off results. The industry standard is to publish the best numbers found for a given test.
- We use fans for cooling purposes only. The industry standard is to provide airflow equivalent to a car at speed.
- We focus on relative results. The industry standard is to focus on global results.
Q: What qualifications do you have to be dynoing products? Do you own a dyno shop? Are you in the automotive industry?
None, no and no! None of us had any qualifications what so ever! But, I think that's the beauty; we had no biases going into this.
We made our interests painfully clear 2 years ago, when we started all this. There were a bunch of people asking the question, "I appreciate what the manufacturer says, but what does this mod really do, for me at a stoplight?" I spoke up and said, "Gee I dunno... how hard can it be to find out?" <------MY FIRST MISTAKE!![]()
From there, we became point persons for the experts, the OEMs and the like. We opened it up (and still do!) to all aspects of experience and qualifications, and then condensed the wealth of information and experience down into something that the 'common man', just like us, can understand and apply. We take the same approach the open source community does; its the community effort that has resulted in the test and resulting valuable info we have today. I hope it continues to be the community effort that will further shape, refine and therefore produce even more useful tests.
Q: What dyno do you use, and why?
The Mods Face Off dyno is a SuperFlow SF840 Chassis with full instrumentation, located at SVS R&D in Sacramento CA. This dyno is absolutely state of the art, and its two 400 horsepower eddy current drums are among the most sensitive available today.
This particular SuperFlow can operate in either "inertia" or "load bearing" modes; and within those modes we can choose various sub modes; "simple inertia", "controlled acceleration", "steady state control" and "road load".
A major benefit of the SuperFlow is its eddy current rollers; they allow us to actually measure both force and acceleration. Other systems we evaluated measure one or the other, and calculate the number it doesn't measure. They calculate this value based on manually input values for weight of the vehicle; and since weight can only be estimated at the time of test, this opens the door for an added variable (of course, we could specify the same weight always; but the car may not actually weigh that weight at the time; keep in mind the general rule of 100lbs = 1/10th at the track, and you can see that its critical to get this number right each and every time, or do as we do and just measure both values and not worry about the actual weight dyno day). Both force and acceleration are required for computing our power numbers, and by measuring both, the SuperFlow can deliver extremely accurate and consistent results.
We were also drawn to the experimentally proven accuracy of this dyno and to that effect we ensure the SuperFlow has been professionally calibrated just before each test event. Advertised accuracy is plus/minus 2%, however actual measured accuracy is sub 1%.
Q: Why have you chosen to use inertia mode rather than load bearing mode when testing?
First a little background on the 4 modes our SuperFlow SF840 is capable of:
The Mods Face Off tests have always been in inertia mode and have used either simple or controlled acceleration. It was determined very early on that the performance numbers in the controlled acceleration tests were "close enough" (1-2hp difference?) to those found with simple inertia mode. It was decided at that point to standardize on simple inertia as it causes much less stress on the vehicle, and is more informative for seeing "up the curve" improvements.
- "simple inertia" is an inertia based mode that uses the mass of the roller to simulate load; this mode is best for acceleration testing (non adjustable load)
- "steady state control" is an inertia based mode that requires a variable load; this mode is primarily used for tuning purposes
- "controlled acceleration" is a load bearing based mode that requires a variable load; this mode is primarily used for finding maximum power numbers
- "road load" is a load bearing based mode; this mode is primarily used for simulation and diagnostic purposes
Load bearing mode was briefly considered, but keeping in mind these are, after all, our daily drivers the higher numbers we were sure to see (around 3hp more per pull) simply didn't justify the exponentially more stressful test on the car; and now that we're over 200+ pulls we all think this was the right decision. The negative of this decision was the 2 gear pull manifestation, rather than (along with other computer tricks that would have been required) the single gear pull ability of load bearing mode. However remember, on that point, with this mode we are able to see true "up the curve" improvements in torque and horsepower. Load bearing would have shown us this effect only minimally.
Q: Why do all your released graphs show MPH for the X axis, rather than RPM like is traditionally shown?
Simple; if we tried to plot it in terms of RPM, the graphs would look like this:
What you're looking at is a two gear pull. Of course, since the transition from the first gear to the second gear drops the RPMs, we end up with the double back you see above. We are working on a tool that will allow us to further define the raw data, and isolate a single gear, but I can't promise when that will be available.
Q: Why the heck do you make 2 gear pulls anyway? Isn't the traditional way a single gear pull?
This 2 gear pull standardization we've lived with since day one is a direct result of the wonderful computers in our 5.7 LXs. They, without significant reprogramming and/or fuse manipulation simply wont let us stick in a gear under power load. They will ALWAYS drop down a gear when WOT is initiated and the RPMs will allow. Of course those RPMs are right where we want to start the pull.
This is not entirely a bad thing however. Due to this 2 gear pull, we've been able to compare shift patterns of various mods. We've also been able to draw "up the curve" or acceleration comparisons; something that would be far less pronounced on single gear runs.
And, ultimately, while a single gear pull (in load bearing mode) is bound to yield larger numbers (and a far cleaner graph), we don't necessarily care! Remember, our goal is to find relative differences in modifications, not global numbers for a given mod. In other words, if a vehicle with mod A shows 100hp and that same vehicle with mod B show 110hp under identical conditions and testing methods, we can safely say that mod B has outperformed mod A by 10%. This ratio will hold true for a single gear pull as well.
Q: Why do you emphasize average results rather than the maximum result for any give mod?
Averages tend to minimize anomalies. Experience with these LXs have taught us that they can act quite differently in back to back runs. The only true way we can see of comparing relative results given this known variability is to select a sample size, and average based on that. We always do publish each and every run's results, so you yourself can see the maximums, but when it comes to conclusions we make, they will always be based on the average of a set of dyno pulls.
...the next
And the dead shall walk
