Mods Face Off Result: Jet Stage II Combined with Superchips 91
This test consisted of testing the Jet Stage II Chip combination with the Superchips 91 tune, on an extensively modified 2005 Magnum RT, and an extensively modified 2005 300C at the Mods Face Off 5 (MFO5).
Mod Tested: Jet Stage II / Superchips 91 Tune Combo
Date: 10/12/06 - 10/13/06
Dyno Location: SVS R&D, Sacramento CA
***Remember to always review and keep in mind the Mods Face Off Testing Methodology Q&A while reviewing these results.***
The Good:
The Bad:
- Rich! Check out those AF graphs for Meister, and you'll see the Jet fattens up the loaded end.
The Numbers:
- Gas mileage; everyone I talked to about this combination reports significantly reduced MPG. My own tests back up these reports; on average I'm 2-4MPG less when the Jet is combined with the Superchips 91 tune.
- Why didn't CoolVanilla show the same change richness in AF? This could mean significant variability between installs (and might have to do with a given mod combination)
- Performance numbers are significantly down for CoolVanilla, and just slightly for Meister. Again, this might be due to the variance in each's specific mod combination?
CoolVanilla's Results:
Meister's Results:
The Graphs:
These two pulls closely follow the averages for the entire set. This is average vs average, not worst vs best.
And the AF ratio comparison for the same run pictured above:
Meister's Results:
...the next
13.504 @ 102.59 BEST
According to WTF: REDEEMED 1st Place B3 class and 2nd place King of the Hill Mopars @ Etown 5/18/08
