Results 1 to 15 of 27
    Junior's Avatar
    Junior is offline LX Guru
    Phoenix
    Mods Face Off Result: AEcarbon's AE Full Intake System (AEFIS)
    Mods Face Off Result: AEcarbon's AEFIS
    Mod Tested: ae carbon's AEFIS (AE Full Intake System)
    Date: 12/4/08 - 12/5/08
    Dyno Location: SVS R&D, Sacramento CA
    Track Location: Sacramento Raceway, Sacramento CA (Canceled due to weather)
    ***Remember to always review and keep in mind the Mods Face Off Testing Methodology Q&A while reviewing these results.***
    The Good:
    • This is a promising design. Both the intake tube and the box have a lot of thought behind them.
    • The "finished carbon" version of the intake tube is a very well-laid piece.
    • The AEFIS is available in two stages, and the box is reported to work with other brands of tube intakes.
    • Since the Stage 1 kit will come with filters supplied from Airflow Innovations, the filter comes in various color options, allowing customization of your engine bay in a new and pretty cool way.
    The Bad:
    • The unit supplied to us for testing is rightly to be called a prototype. It was not (at the time of testing) a production-ready unit.
    • The unit did not fit in the engine bay of our test Magnum (and will not, until significant changes are made). Fit in a 300C was not verified, and remains to be seen.
    • Our unit did not come with installation instructions.
    • The installation of the Stage 2 kit requires removal of radiator shrouding on the driver's side of the car.
    • Hard answers as to the differences between this unit and what may be available in the future are as of yet unavailable.
    COMMENTS:
    The AEFIS was alternately called "ready to market" and "prototype" in the weeks leading up to, and even during the event. The fact of the matter, in the eyes of the ones doing the testing, was that the supplied unit was not production ready; and as such should not have been included in the MFO, which has always been a venue only for products on the market.
    However, the unit was tested, in various configurations. The reasoning behind why this was the case has been explained HERE and HERE.
    As a result of being provided with a unit that was not production ready, the results of the tested unit are not being included in the official results. They are, however, valid results - as long as one understands and keeps in mind the information concerning the testing of this particular unit, and the fact that changes between this unit and what will be available for sale are likely, if not necessary.
    Junior's Avatar
    Phoenix
    Everything you see below is what they call structural (or paintable) carbon. They plan to also offer these kits in finished carbon, as seen on their own threads.
    Thumbnail
    Click to view the original image
    Here's the rubber seal, and the clamping surface:
    Thumbnail
    Here are some pictures of the box:
    Thumbnail
    Thumbnail
    Thumbnail
    Thumbnail
    Thumbnail
    Thumbnail
    Thumbnail
    The PCV nipple is mounted to the box, and there is an integral mount to slide into the hanger on the coolant reservoir:
    Thumbnail
    Here are some pictures of the air scoop:
    Thumbnail
    Thumbnail
    Thumbnail
    Thumbnail
    Here is the hanger tab:
    Thumbnail
    Some shots of the lid, and the contour that meets the seal around the intake tube:
    Thumbnail
    Thumbnail
    The rest of the shots were taken at the MFO.
    This is what will be known as the Stage 1 kit:
    Thumbnail
    This is what will be known as the Stage 2 kit (included, but not visible, is the air scoop):
    Thumbnail
    Here are some miscellaneous installed pics (captions when I have more time):
    This is the reason it won't fit on a Magnum:
    Thumbnail
    This is the air scoop installed:
    Thumbnail
    This is looking into the box, and seeing the air scoop installed in front of the box:
    Thumbnail
    The hanger tab never did meet up with the hole it's supposed to mate with:
    Thumbnail
    Here you can see the poor fit of the cover:
    Thumbnail
    Thumbnail
    Thumbnail
    Looking into the box from the tube side:
    Thumbnail
    Thumbnail
    Some more interior box shots:
    Thumbnail
    Thumbnail
    Thumbnail
    This black plastic baffle is the piece that must be removed in order to use the air scoop (though it is NOT necessary to remove the fascia in order to remove the baffle - this one was already off):
    Thumbnail
    rwalshphoto's Avatar
    rwalshphoto is offline Matte White Wagon
    Phoenix, AZ
    very nice Mike thank you for the photos and the review!
    Starting over with a new Magnum RT (SRT8 Conversion)... 6.1L with SRT Max Cam, Corsa catback with chambered center pipes, Sinister Extreme dual ram intake system, SRT Suspension, silver Brembos, graphite powder coated Charger SRT wheels, frost white intake manifold (ported) and valve covers, matte black engine bay, carbon fiber engine accents, 300C SRT8 Front end, Matte White vinyl wrap, Black Ops 300-Challenger style carbon fiber hood. Project "SnoMachine" all work performed by Arizona Hemi Specialists - Plum Floored Creations, Mopar Automotive Photography
    aecarbon's Avatar
    aecarbon is offline that's nice....but mine is Carbon Fiber!
    Jul 2008
    The Sanitarium
    Thank you very much Mike!
    Quote Originally Posted by gooeytek View Post
    "The suspension combo is ideal. I went with Hotchkis sways from the deal given by THMotorsports, and the K Sport coilovers from AE Carbon. Also got Stack's strut tower brace. Cornering is less dramatic, with barely noticeable body roll. The coilovers are currently at the middle setting, and the ride is very sporty but not harsh at all. I can compare the dampening to my brother's new E550, except that the Mag seems to corner better as well."
    gooeytek's Avatar
    gooeytek is offline heavy hemi
    Jun 2008
    Lake Grove, NY
    That is one beefy intake! daddy likes!
    http://www.lxforums.com/board/signaturepics/sigpic23029_3.gif
    MY HEMI REGISTRY PAGE
    ... Do it for fun and enjoy the improved performance, but don't think you made a transaction that makes any financial sense. Use the economy numbers to torpedo the tree hugger who wants to get snooty with you, but know in your heart you did it so you could go faster.
    BigHemi06's Avatar
    BigHemi06 is offline Race It????.....NO NO NO It's A Show Car
    West Palm Beach, FL
    Very nice Junior....cant wait to see more on this setup !!
    Mods: 6.1 motor with PPP Ported Heads and 224/228 598/578 113LSA, stock tq converter, stock SRT headers with gutted cats, JBA 3in exhaust, LMI hammer design intake. The only 6.1 motor running a 2.82 rear.....Soon to be 3.06 gears.....Installs done by Afterhours Mopar Performance
    STAGE 3 R/T's Avatar
    Jan 2006
    Argyle, Tx
    I want one dang it!
    Redfox0099's Avatar
    North Charleston, SC
    If I was still N/A this would be the 1st thing I would install for my 426...no questions asked.
    eldiablosrt8's Avatar
    eldiablosrt8 is offline el diablo srt-8
    Mar 2008
    pleasanton,ca
    thanks junior for the right up! we do appreciate everythign you have done. i will be in the area during dec and jan maybe we can hook up and do lunch or dinner. again thanks for the right up and the great detail
    Junior's Avatar
    Phoenix
    Maybe I wasn't as brutally honest as I thought I was... All you aecarbon dudes are thanking me - I wasn't trying to be harsh, but I was making sure to point out the flaws we found too...
    Anyway, I think you guys have the potential for a great product, and if you get it refined and get the bugs worked out, you'll do well with it. It needs a lot of work, but I've seen the other things that have come out of that shop, and if this AEFIS ends up as well-made as what I've seen, you'll do well.
    Phoenix, AZ
    Quote Originally Posted by Junior View Post
    Nope, we are thanking you for your honesty and your and others' time. The more feedback we get the better the end product will be. And you can definitely count on dyno, track, and heat testing of our intake of the exact production unit. We knew the parts we sent had some issues and we've been working to resolve them and test fit on all 3 vehicles since then. We will continue to push forward to release this intake and produce horsepower for LX vehicles.
    MoPOWeR-349's Avatar
    MoPOWeR-349 is online now Whiskey Tango Foxtrot: Buster Buster
    Nor Cal
    Quote Originally Posted by rwalshphoto View Post
    Is there a time table when this will be in production and ready for sale.
    aecarbon's Avatar
    Jul 2008
    The Sanitarium
    Quote Originally Posted by MoPOWeR-349 View Post
    In about 2 weeks or sooner
    Jan 2006
    Argyle, Tx
    Well where is my #0002? lol I can't wait for her to arrive!
    aecarbon's Avatar
    Jul 2008
    The Sanitarium
    Were taking pre orders for this unit so you can be the first on your block to have one (and the strip)
