I have a few runs under my belt as well and when testing centrifugal superchargers they are very susceptible to heating up the intake path. Does the number stay at the llower levels aftyer the initial passes? Log your IAT and see if you reach a soak point.
I don't know how the adaptives work with the Hemi and I also don't know what the scalars are for timing and fueling at WOT. Voltage and IAT can have a very large impact on the top end of the curve.
When testing anything for gains I have always found it best to start at a number you can get to (180deg coolant, 200 deg oil, whatever) and make three runs.
Look at the runs and you will find that runs in the series will be comparable to other runs in the series I.E. 3 runs 001, 002, 003 compared to runs 004, 005 and 006. Compare 002 to 005 for greatest accuracy.
Not running in the vehicle is one of the bigger reasons for poor repeatability. It takes some time to get the rear gear oil up to temp. When I ran dry sump cars we would have to run up for about 5 to7 minutes with the Oil sump at 180 deg to circulate the oil in the motor and we routinely heated the rear diff oil to 180 deg as well.
As for the fan, as long as you use the same fan all the time and you have the dyno intake temp probe reading inlet air you will be fine. A dyno can't give a final HP figure but an inertia dyno and a good operator can give a very repeatable (within the ability of the vehicle) result needed to find the Next Great Thing!
Hope this helps,
Sean
