Results 1 to 15 of 26
    CoolVanilla's Avatar
    CoolVanilla is offline The Dude Abides
    GIFO/Modifications Face Off Summary:Got a performance question? Find the answer here!
    In an attempt to aid searching, I've created this thread that will hold a summary of all performance tests we've made thus far, and those we'll make in the future. Please feel free to post general questions here. Any specific questions about a test, please post them to the appropriate, linked, thread.
    The Great Intake Face Off (GIFO) Series of Tests
    GIFO1 - Various CAI products on a bone stock RT
    • This test involved a stock 2005 Magnum RT. Various intakes were installed and were tested under similar conditions. Dyno results and track times were gathered.
    • The bottom line? No aftermarket intake tested showed better max hp and torque numbers than the stock box. However, looking at "up the curve" results, we can see slight improvements, around 8/8. Net result? A slightly harder pulling Hemi.
    • See all the details here: The Great Intake Face Off - RESULTS!
    GIFO2 - Zoomers Aftermarket exhaust and various CAI products
    • This test involved the same 2005 Magnum RT on the same dyno, but this time with Zoomers aftermarket exhaust installed. Dyno results and track timers were gathered.
    • The bottom line? The exhaust modification is worth just around 10hp and 10torque max output. No aftermarket intake tested showed better max hp and torque numbers than the stock box. However, "up the curve" improvements were seen with the exhaust of up to around 30/30! Net result? A harder pulling ride at WOT.
    • See all the details here: http://www.lxforums.com/board/showthread.php?t=16139
    GIFO3 - Gibson Headers, 18" vs 20" rims, GSM Traction Mod, and various CAI products
    • This test involved the same 2005 Magnum RT on the same dyno, but this time with Gibson headers, and the GSM Traction modification installed. Dyno results and track timers were gathered.
    • MattRobertson had his headers installed and tested by the same folks. See his results here: GIFO3 Sidebar: MattRoberston's Gibson Header results
    • Meister ran his 300c with 3 different configurations on the same day my headers were installed. See his results here: GIFO3 Sidebar: Meister's Dyno Results
    • The bottom line? We saw a max improvement of around 20/20. This is consistent throughout the power curve. AND for the first time, we can see a substantial improvement with an air intake; around 10/10 max. Oh and 18" vs 20" rims seem to make zero performance difference for our setups. As for the GSM mod... I suggest you read the linked posts and draw your own conclusions.
    • See all the details here: GIFO3 - Headers, 18" vs 20" & GSM Mod RESULTS
    GIFO4 - Superchips tuner, Hypertech tuner, Jet Stage II chip, Hurricane IAT mod, StarScan Dyno Mode, Octane tests, various CAI options
    • This test involved MattRobertson's 2005 Magnum RT on the same dyno, but this time with the various mods applied. While we didn't show any particular major benefit with the Superchips, we did show that it was very effective at reducing the dip in power between tranny shifts; that alone justifies the mod. We also showed for the first time a filter degrading performance due to it being undersized.
    • Meister ran his rig with his monster air filter, and showed yet again bigger is truly better. He also showed that stacking the Jet Chip with the Superchips tune might be worth some gain, but its not necessarily an advisable combo.
    • gotls1's RT was tested using various octanes of gasoline and the Superchips tune for those octanes. We saw significant drop offs when 87 octane was used, however no real increase in performance between 89 and 91 (premium here in Californai). Bottom line? Save some pennies and run with the 89 if you have anything close to a stock 5.7L Hemi.
    • Many other members had the chance to run their LX, including an SRT8 and Supercharger.
    • See all the details here: GIFO4 - Perf Results, Analysis, Comments and Meet & Greet Pics
    Test Series Renamed to the Modifications Face Off series ----------------------
    Mods Face Off 4.1 - High Horse Performance High Flow Catalytic Converters & Frankentake II
    • MattRobertson put his Magnum up for test yet again on the SVS dyno. This time, high flow cats were installed and the Frankentake II was tested.
    • These cats are worth approx 9hp/12trq with Matt's given setup. More power+better sound makes this a must have mod.
    • The intake was tested after the engine had heated, so the results are not clear.
    • See all the details here: MoFO 4.1 - HHP High Flow Cats & S&B Frankentake II - RESULTS
    Mods Face Off 5 - Coming Oct 9-14 2006
    • Click here for all the details.
    GN_driver's Avatar
    GN_driver is offline LX Newbie
    Upstate SC
    CV, hope I am not missing something really obvious but I want to add an aftermarket catback and want to know how much better than stock they are, which ones do better and where bottlenecks of the stock system are. Anything planned or done already?
    Thanks for all your input.
    05Magnum R/T Built 02/05, Superchip
    done's Avatar
    done is online now Member for 7 years
    Old Hickory, TN
    Quote Originally Posted by GN_driver
    From post #1
    Thanks Don. Does that answer your questions GN? If not, do not hesitate to ask anything else!
    NorthernCali is offline LX Newbie
    May 2006
    Quote Originally Posted by done
    From post #1
    I was curious if the same number apply for the srt8s also? Does it make a differance if i just swap the mufflers only vs. replecing the whole cat back + mufflers? I was also wondering if removing the resonators make a differance?
    Bubba's Dragon's Avatar
    Bubba's Dragon is offline The NEW KRT
    Mar 2006
    Daegu, South Korea
    So is getting headers worth it? Just purchased DUB intake and Basani exaust. Will adding headers help me or should i go internal and think about heads and cam?
    KRT:
    2005 BLACK Dragon:
    MODS: None, pure Natural Dragon
    mr.niftie's Avatar
    mr.niftie is offline LX Love Machine
    Oct 2004
    Oakville, Ontario, Canada
    Sorry for what may be a dumb question but what is "up the curve"?
    Quote Originally Posted by mr.niftie
    Not a dumb question at all! I should have explained better.
    When I say "up the curve", I'm meaning the curve the torque and horsepower numbers make when graphed. Even though one mod might net the same performance numbers as another (ie mod x = 298hp max, and mod y = 298hp max), how they get to that max is just as important (if not more so) than the max number itself. (ie at 3500rpm mod x was at 234hp, while at 3500rpm mod y might be all the way up at 255hp).
    Let me put it another way: if mod x is making 250 hp after 5 seconds of WOT, mod y is making 280 hp after the same five seconds of WOT. We would say that mod y shows a vast improvement over mod x "up the curve".
    I hope that makes some sense.
    (all numbers used are fictitious and are not meant to be taken literally; they are for example purposes only)
    HEMI~C~'s Avatar
    HEMI~C~ is offline Ahhh..blown, stroked and injected!
    Oct 2004
    Raunds, Northamptonshire UK
    All, I can't seem to find any of the results/dyno sheets related to this weeks testing. I saw the heads/cam testing done on one vehicle and the AirHammer Ram air mentioned by Meister but not much else.Am I missing the obvious or just being impatient?? Thanks for busting ass this week guys.Chris
    RobAGD's Avatar
    Reston, Va
    Hemi~C~ - Its going to take about a week of solid number crunching to get everything going in the right direction. I wouldnt expect to see any more than very general graphs until next week.
    -R
    Morid's Avatar
    Morid is offline LX Newbie
    Apr 2006
    Spotsylvania, Va
    I have the same question!
    Quote Originally Posted by Bubba's Dragon View Post
    See above, Didn't see an answer. Thanks!
    Morid, check out the GIFO3 section above, and if you want more info click the link contained within it. If you still have questions after reviewing our findings and comments, please feel free to post em up! Just keep in mind, the "worth it" question is really too subjective for me or anyone else to answer. What we can do is show you the performance numbers and help you decide if the $$ and effort are justified for your particular driving style and goals.
    UK CHRYSLER 300C's Avatar
    UK CHRYSLER 300C is offline LX Padiwan
    I hope somebody is still watching this post,
    what sort of improvement will I see if I use a Diablo and a 180 stat on a stock 5.7 UK spec 300C,bearing in mind that what I have found out that some U.S. models are speed restricted to 128mph while UK models are restricted to 155mph.
    What I really want is better bottom end. i.e. acceleration,as I'm not bothered about top end.
    I dont want any other mods,as I know through experience that CAI's just make noise and the horsepower lost through cats is only about 10%.
    I have always had and will always like the "street sleeper".and in my day it was through bigger engine/carb swaps,(blaa,blaa,blaa.lol)Also if the diablo is fitted will I still have to pull fuse 11 every now and then to pep the power up.
    Thanks from the UK who has no-one to help him.
    Meister's Avatar
    Meister is offline 300C pilot
    Arizona
    Quote Originally Posted by UK CHRYSLER 300C View Post
    1....what sort of improvement will I see if I use a Diablo and a 180 stat on a stock 5.7 UK spec 300C...
    2....I know through experience that CAI's just make noise...
    3....if the diablo is fitted will I still have to pull fuse 11 every now and then to pep the power up.
    4.Thanks from the UK who has no-one to help him.
    1. You'll likely see 15 hp or so - more if you follow the suggestion in item 2.
    2. That *used to be* an accurate blanket statement, UK Chrysler, but not any more. Our own MoFo's have clearly shown the AirHammer to make 10 hp or so on a totally bone stock LX 5.7. One other intake made about half of that.
    I can HIGHLY recommend any of the several great AirHammers available for you to choose from. I would think that the 6# weight savings you get with the al-you-min-ee-um model would help offset its extra purchase cost by saving you a bunch of money on postage.
    With the AirHammer installed the Predator will now make additional power of its own, so you may see upwards of 30 hp.
    3. It's doubtful. Typically you'll be changing parameters in your Predator frequently enough that your ride never develops the doldrums.
    Help is never further away than your keyboard, UK.
    I dont really want a CAI,if i had a challenger or magnum maybe,but the 300c doesnt look sporty enough to have that "baaaarrp" noise,In the UK the 300c is classed somewhere in the top marque,thats why I had the C,cos its a street sleeper.
    you say about 15hp increase on stock settings,doubt i'll feel that,but i'm sure i'll feel the tranny difference,plus i'm led to believe that i can shift the red line higher,is that true too?,thanks again
