Results 1 to 15 of 19
    SMITHVD1's Avatar
    SMITHVD1 is offline LX Newbie
    Jan 2007
    HELP! Water spot removal
    I need some help with the water spots on my 1998 Dodge Stratus. It sat in my driveway for 7 months while I was deployed to Iraq. The sprinkler hit it twice a day. The water on my side of the island has a high mineral content. The water flows down from the mountains so HI does not use florine and the chlorine content is low as well. I have tryed two different products. One of them came from NAPA Auto Parts and the other from a Marine Supply. I'm not home so I can't get the names (I'll edit and add them later). The one form NAPA takes alot of elbow work. I've used it with my orbital but it does not get them. The stuff from the Marine supply is applyed and rinsed with the hose. Same results. Is there anything I can do besides wet sanding? The entire drivers side and most of the hood and trunk were victams to the water spots. Thanks
    hops23's Avatar
    hops23 is offline Motor Fan Club member
    Nov 2005
    Chicago, IL
    Have you tried a clay bar?
    2005 Inferno Magnum R/T AWD traded
    2007 BSM Charger SRT8 traded
    2008 BSM Jeep GCSRT8: Option Group I and II.
    SMITHVD1's Avatar
    Jan 2007
    Quote Originally Posted by hops23 View Post
    I almost purchased the bar and detailer yesterday but it said it only removed suface contaminates. So I didn't know if it would work. Will it?
    ZMagnum's Avatar
    Tucson, AZ
    You should try that clay bar. I've not had such a bad water spot problem myself but I've heard it will work on them.
    Fight On!'s Avatar
    Fight On! is offline LX Newbie
    Jan 2007
    CHino Hills, CA
    Yea, I used the clay bar on my sons car it worked with a little elbow grease. The great part was it did not hurt the car 1 bit.
    COOKZ32's Avatar
    COOKZ32 is offline AK RT C-LEG DAVAF
    Feb 2006
    Minnesota, we need longer ski runs
    There is a thread on this last summer, and it had some really good simple things that posters used and had really good luck with. I'll search as soon as I'm done with homework, 6th grade, and if you have not found it yet I'll put a link to it here if I can find it.
    07 Super Bee 0991 * SRT8 pedals custom install by F1fan - Rick and Jina SUPERBEE's - Gloss Black Decals and Custom Paint by Maple Plain Auto Body, Leanord - Seq. Turn Signals, Flashing 3rd brake light - Billett Technology Caps - BMC Performance - DMH Cutous - NoEsp&Fan - Hotchkis Sway Bars - Saint Paul Automotive, Scott - Crazy Luck rear deck BEE - Freebird BEE on custom plates
    RobAGD's Avatar
    Reston, Va
    The question I have to ask is, is it "spots" like mineral deposits or is it "spots" from where it etched into the clear coat ?
    They are very differnt things
    -R
    SMITHVD1's Avatar
    Jan 2007
    -R
    I really don't know how to tell the difference. Is there a way? Up until this my paint had a goodh shine even though the car is almost ten years old now.
    I'll pickup a clay bar and detail spray on my way home. If it doesn't work I'll have it for my Aspen when I'm prepping it.
    RobAGD's Avatar
    Reston, Va
    etching will look liek small craters in the paint. It can still shine but when you look at it you will see what looks liek craters, I have small water etching so it looks like th moon, I have seen where bigger puddles have sat and left huge marks.
    The Clay may not do a whole lot for you, but its worth a shot, just make sure to use only 1/2 teh bar at a time, that way if you drop it you still have 1/2 the bar to finish with.
    -R
    SMITHVD1's Avatar
    Jan 2007
    Reppr's Avatar
    Reppr is offline join date 05/06/2004
    May 2004
    Gig Harbor, Wa
    Okay, the best, hands down, polish, spot remover is Maguiars #83 Dual action Cleaner/Polish. It will take any mineral spots out of the clearcoat and will also take out scratches and "spider webs". It also will not harm the clearcoat and you can use it as much as you want. This comes from extensive experience.
    Member #197!
    Ah, screw the diet.
    lowriderman3's Avatar
    lowriderman3 is online now Rut Ro!
    Low Down Dirty South!
    ^^Can that be store bought, from like an auto parts store. Or does it have to be ordered?
    RobAGD's Avatar
    Reston, Va
    if you find the right store yes.
    I belive they are refered to as PBE stores, if the supply paint supplies and parts to shops they will most likely have it.
    If you want to order I suggest http://autodetailingsolutions.com/ they have some good packages and decent prices.
    -R
    ^^Thnanks!
    BuckeyeRT's Avatar
    BuckeyeRT is offline Life is fragile, handle with prayer.
    Jan 2006
    Home of The Buckeyes
    Quote Originally Posted by reppr View Post
    I think 83 might be a bit too agressive to start.
    Great link for water spots:
    http://meguiarsonline.com/forums/sho...&threadid=4891
    Got Faith? Philippians 4: 6&7
    Yup, Haz did my sig too.
    Ask me about my first kill, I bet it was better than yours!
