my engine is dirty as hell. i want to spend some time cleaning it. what do you guys use if you use anything at all.
Simple Green... 3 parts water 1 part Simple Green.
2005 Dodge Magnum AWD R/T (MINE) - MySpace Profile
2006 Chrysler 300C SRT8 (Wife's)
RIP
12.869 @ 102.02 Stock 5.7 w/ C&L, Predator, JBA Cats, Volant catback, DRs & skinnies
Is Simple Green A Brand?
www.simplegreen.com
Yes it is a brand, but also a type of cleaner, available just about everywhere... (Wal Mart, Target, Auto Zone, Pep Boys, Advance Auto, Kmart, etc etc)
Humour us... take before and after pix so we can see how the clean up went
Russ
- Falken 20" Explict Black rim,Falken 255 45 20 tires,8"LCD monitor headrests,12" LCD monitor in custom tri fold in back,custom made CIA,Infinity engine cover w/custom paint,custom painted centre bezel & console,custom lit cup holders, LED interior lighting & grill lites,HID's,300w sub amp w/custom enclosures,custom hand-made mesh grill
Ok Will Do. Ill Take A Picture Tomorrow Of What My Engine Currently Looks Like And Then When I Buy The Cleaner Ill Clean The Engine N Post A Pic . Thanks Guys
What Do You Guys Mean By 3 To 1? Do You Guys But The Simple Green In Water Then Take A Sponge And Clean It Off?
no...put into a spray (3=water to 1 part simple green)bottle spray all over ...and like said prior ...don't get on paint...will take wax off....you should do this before you wax car
engine should not be hot but can be warm....let it set for a while and spray off with hose...a fine mist or light spray...don't go nuts...and try not to hose the electronics too much...but don't worry about it everything is sealed nicely.
RIP
you could actually hose down your engine?
yes...it's not like the old days....but like said don't go nuts a fine mist or soft spray is all that's needed....powerspraying will get the solution on the fenders etc...you should rinse the fenders etc. afterwards as well to guarantee the solution is not on there...... if you have tough spots....a soft brush with the solution will take care of it.
Stell
RIP
I just cover my intake filter up then spray the whole engine down.
