Is it possible to over lubricate when clay baring. Basically having the clay bar glide to easily and not allowing it to pick up all the contaminates. Or does it matter how much you use, as long as the clay bar glides smoothly over the paint?
2005 Dodge Charg-um R/T
Midnight Blue!
Mods:
JBA "Shorties", Highflow Mids, Borla catback!
Spartan Max Cam, Fri Ecno Heads, CMR Tune!
Console Cover "Magnum R/T"
Taylor Wires
BT Pistol Grip Knob #17 (Only Limited one in blue!)
BT HVAC Knobs "R/T", Nav Knobs, Shift Bezel, Etc...
Custom Cargo Shade (Embroided by Jina's Sew Simple)
Airhammer
from my experience,,, it doesn't matter, the clay bar pics up anything that is above the paints surface... its better to be wetter!
Steve Burkett
"Killing Time"
Current Sponsors and Supporters: 2Crave Wheels,Webasto Sunroofs,Katzkin, Dresden Designs Grilles, MGP Caliper, Covers R1 Concepts, Kicker, Fatmat Sound Contol, Xenon Bodykits, LA Kustomz Air Ride Specialists, Viair, K&N, Borla Exhaust, Cutting Edge Graphics & of course my Fiance Andrea for putting up with the build!
What you should be concerned about is not lubing enough, not over lubing [unless you use expensive products and care if you waste it]. If your clay grabs the paint, you need more lubrication. In theory, lube isn't going to "buildup" to the point where your bar doesn't work effectively, so spray away!
What are you using as your lube?
His / Hers KY. J/K
Megu. Ultimate Detail. I am using their paint restore kit and this is my first time claybaring, love the results so far, still have 1/2 the car to finish up.
I usually only use about half a bottle of the spray stuff when I clay.
2008 Charger SRT8 dubbed "The Sequel." Black on black is back.
Tell your friends.
yeah, one can go through alot when claying...like said above "the wetter, the better", if you hit a dry spot, you risk marring the paint.
Use the cheaper quick detailer when claying. No sense going expensive when you're about to throw polish or wax on it.
No.
Buy some ONR and use that for clay lube. It's a fraction of the cost of quick detailer products.
Just lurking. Hemi Registry #1050
suprised no one mention this. I use ricardos clay and there is "mild" and "aggressive" I noticed some other companies also offer the same. If your paint is full of crap then you may want to use a more agressive clay
Thanks for the replies guys. I got her all claybared, hand polished and waxed. I used about 3/4 of a bottle on the car. One thing I did notice, the rear of the Maggie was nasty it dirtied up the clay quicker then the rest of the car.
pics??
After using a whole bottle of detail spray I just stick with a lot of soap and water
Can't over lubricate. Clay bars do more than pull contaminates out of the paint, they are also a polishing device. All clay bars also polish, some are more aggressive than others. If you use a bar that's labeled as "Aggressive" you will probably need to use a good glaze afterwards.
MoparMax Magazine
Driver: Alex "The Car Girl" Rogeo
2007 MSRT8 Powered by Arrington|Magnuson Supercharger|Hedman Long Tubes|655 rwhp 715 lb ft
DSS Axles & Driveshaft|OS Giken LSD|3.55 Gears|Unitrax Drivetrain
3000 stall|Westminster Transmission NAG1|B&M Flexplate|Mopar TCM|LAT OIL & ATF
Diablosport Trinity|Mickey Thompson|RPM Rollbar
10.98@127 mph
NHRA PSCA WCHRA
2012 PSCA Street Muscle Championship Runner Up
