I saw this in Autozone today. Turtle Wax site
I was just wondering if anyone had tried it.
I was tempted the other day. Went with the regular old clay bar instead. I'm sure it works pretty good but I can't see how it would remove the stubborn cooked on contaminants the bar removes. It was almost as expensive as the real kit so I went with old faithful.
A "liquid" clay bar? sounds like a standard paint cleaner - I will stick with the real bar also.
I wondered how much of the product description was hype.
I just like the term exfoliant.Turtle Wax® ICE™ Liquid Clay Bar is a revolutionary new way to deep clean and restore your car's finish in a fraction of the time it takes with traditional clay bars. A unique triple layer formula consists of a scratch & swirl remover, cleaning agents and an exfoliant that work together to provide outstanding cleaning capabilities.
Exfoliant
Definition: a cosmetic product or ingredient intended to remove dead skin cells and dirt from the skin surface.![]()
oh thats nothin
you should see some of the "drink responsibly" ads I make for the brewery.
Thats lkike a crack dealer with a just say no t-shirt.
Hi all. So what is a clay bar and how & when is it used?
Thanks![]()
you buy it at your auto parts store. It's an actaul piece of kneadable clay. Used with detailing spray, it removed everything on your paint. If you can feel it or hear it when ya run yer hand accross it, it'll go away. The contaminants on the paint adhere to the clay. It's the clay that pulls it off, hence our thinking the liquid is an overpriced liquid wax.
I think I said this somewhere else but that stuff is like Armor All, most people say to stay away from anything turtlewax lol. But then I heard that the ICE wax is actually good *shrug*
And today a friend was telling me about this foam spray system where you just spray this foam soap on the car and rinse it off. I WISH! I spent like 2 hours washing the car sometimes JUST washing and drying not waxing or any of that.
I got some mother's clay. Will try it tomorrow probably but given how long it takes to clean the car I have a feeling it'll take DAYS to clay it :(
I'll jump in - you should claybar the entirety of the painted surfaces (you can use it on the glass, too, if you have bad water spots or something, otherwise there's no reason to). The detailer doesn't matter too much as far as the claybar goes - it's just there to act as a lube, so the claybar doesn't drag or stick. I like the Meguiar's quick detailer for claybarring, and it's also a great quick detailer, as it turns out! I use Zaino stuff mostly, but their sprays are too thick for quick detailing and claybarring...
You don't have to claybar often; some say once a year, others say more often - but you shouldn't claybar unless you can immediately follow with a coat of protectant (wax or Zaino or whatever). Hope that helps.
Also, back to the original post - I think any of these things that are "an easier version" of something else (liquid claybar or no-touch foam) are usually nonsense. It always takes elbow to do these things right...
I would be careful buying detail items from local stores.... in most cases, they are wannabes and will do damage to your paint.![]()
