Zach and family at Universal Air,
Just want to say your product is SECOND TO NONE! FREAKIN PERFECT! Here are some pics... It took the two of us (Darrell here in Hawaii with the same Magnum and coilover setup) not even 7 hours!!!
THANKS AGAIN FERGY FOR HELPING ME OUT! I learned a lot today!!!
FEEL FREE TO PUT THESE PICTURES ON YOUR WEBSITE!!! THANKS!!!
Kevin
OK, I get it now. All I have to do is move to Hawaii then my car will have an air ride? sounds fine to me.
Looks low, and low is, well, GREAT!!!!
Nice looks sick with the 22 tis'
aaah very cool![]()
Hey HawaiiHemi! Im a air suspension stalker! Can did you take any pictures of the install? How many boxes did the kit come in and does it have 4 way control?
Price and do you recomend this kit to others.
KRT:2005 BLACK Dragon:MODS: None, pure Natural Dragon
the ride is great i think it handels just as good or a little better than the KW V2's I had...
sweet...i was thinking of air ride for a while, but they have problems in the cold...looks great...take care, jimmy
Jimmy - BRIGHT SILVER METALLIC SRT8 I,II,III2toned Flat Black Vinyl,CarbonbyDesign,Billet Tech Designer,Razor Edge,SpeedLogix,KW v2,Predator 91 tune,22" 3 pc Covet Forged Wheels ,Nitto 420s,BWoody Sway ends,Hotchkis sways,Magnaflow highflow/c-back,DMH electric cutouts,22elite,BND ALL Quantum Blue/ACESIV,Killerglass,GSM intake,Danko v2 spoiler/Chin spoiler,Grip Rockers,Neffywrap
They're no good in the cold. Could anyone elaborate?Originally Posted by boschargerrt
The problem is no matter what you do when you compress air it will generate water, and when you experience extreme cold the water inside the air system will freeze inside the valves causing them to be "stuck".Originally Posted by Duke_132
With the use of water traps it will prevent the water from even entering your air system, however you will need to drain them.
What we do to prevent this is to mount the valves close to heat source, i.e. mount them inside the engine compartment, or the trunk so if they do become frozen the heat will "thaw" them out.
Also you can pickup from a local trucking supply an additive to put inside the tank to make it not freeze. Its the same system (lines & fittings) as the semi trucks run for the air brakes.
Looks sweet!!!! You guys are getting it down! Everyone you do will be faster & fasterOriginally Posted by hawaiiHEMI
sweeeeeeeeeeeeeeet!!!!!!!!!!
Nice.. welcome to the sled family.. I went with a kit designed by Paul at PMA motorsports with 3" rear cupsand 2b6 bags..
