I looked through the show off your trunk thread... holy F'n **** theres some outrageous systems, detailed, etc.
Is there a basic system that would allow me to simply raise and lower the ride on one or two ( F or R) switches? IF I were to get bagged, it would be more for tucking some new wheels, being able to lower ride height but not have stiff suspension. I just haven't the experience with these setups to know if theres a like starter setup (then once our bagged your tagged for the 5x 10gal tank, 8 compressor yada yada yada.... so much stuff into these systems.
2d question, if there is such a newb setup as I'm hoping for. Is it possible to mount the tank where the RT suitcase muffer goes (I'm an SXT so plenty of room under there) and would one compressor work, trying to figure out where to mount it all with my self-imposed restrictions.
Thanks.
Charlie
Charlie - 07' SXT Brilliant Black
they sell a standard kit comes with a three switch which makes either just the front just the rear or all at once go up and down this is what i run and works great for me i just use it when i park...
if you look up the kit on there site it shows what it comes with: https://www.universalairsuspension.c...a29aa71f3b2628
you might want to take some measurements of the area you want to use and see what other tanks are available i think the one in the kit might be to big...
I would also suggest giving them a call Zack knows his stuff on air
New Ride In the Making! Like it on the Book and watch the build progress
Thanks much Al. Will be looking into something like this.
