Modding the billet mounts for koni yellows
FYI in order for the billet mounts to work with the Koni yellows a minor mod of the upper mount is needed
Upper mount before,notice only about 1 thread is showing on the shaft
Upper mount after, now full thread engagement is possible
You will also need to go with a larger dia. washer on the underside as well
It replaces this one
Your also going to need to trim the bolt heads on the bottom of the plate for proper fit on the bag
From this
to this
So there ya go,all trimming /cuts were done on a lathe,D
'08 R/T,R&T,Mopar CAI, strut brace & rear air diffuser,Diablo 91 oct CAI tune,BT waterneck,catch can,fusebox,strut & cap covers,Jet 180* t-stat,RE hood/trunk strut covers, UAS, Accuair,Progress F&R sways,SPC UCAs,JHS adj. camber links,Bwoody end links,Koni Adj. shocks,22" staggered Lexani LX-15s,Painted ABS cover,radiator tank,firewall & radiator shroud,Stainless braided lines,3Gs custom cover insert,Tinted windows,tails,BFX HIDs,VDI doors,Billet pedals,Hurst billet shifter,R/T logo trunk liner,Flowmaster super 40s, Blastin' bob resos,4" DW tips.1999 Dakota CC R/T
1968 Charger R/T
ATTN Zack/UAS ru out there?,D
- You may not post replies
- You may not edit your posts
Forum Rules
