Hey guys I was just wondering if there any signs that your compressors are about to go bad. Thanks
I have had them for a about 2 years now but recently one of my leader hoses blew off my viair 480 but viair sent me a replacement hose but that same compressor is seems like its barely on it doesn't vibrate or get really hot like my other 480 compressor
It may be that its now pushing out air like its suppose to and not always running at high pressure. You may want to check the other compressor and make sure its able to blow air out easily from the hose.
You can always hook up a gauge to the pump and see if its building pressure.
So could my check valve on my leader hose not be working could that also be a problem
Ok thanks I'll check out my check valve
