Results 1 to 12 of 12
Thread: Tire Calculator
    DMAG's Avatar
    Feb 2004
    New Yawk
    Tire Calculator
    Thanks to rickcrocetti for supplying this great link for calculating tire sizes and speedmoter changes with different tire sizes.
    Car / SUV / Van / Light Truck Tire Calculator
    Anthony
    7thS0N's Avatar
    7thS0N is offline She's done heck darnit!
    Tampa, FL
    Good link. No fancy picture of tires like the one for the Miata club, but good info (and more detail about speeds).
    Performance: AirHammer, Hi-flo cats, Bassani exhaust, Predator tuned, Mopar perf springs, Hotchkis sways, BT catch can, EGR delete
    Interior/Looks: Custom embroidered Katskins, custom embroidered console & cargo covers, tinted tails (Charg-um), Upper and Lower grills (NC-SXT), 'Cuda stripes, 20" Torque Thrust-M's, MoPower Shaker, MoPower Chin spoiler, PAINT!
    Tunes: Pioneer F90BT, JVC Arsenal KS-AR8004D + Kenwood KAC-7204, Infinity Reference setup including 2 10" subs in custom embroidered RobbyHo enclosures
    bipto's Avatar
    New Hampshire
    Great to have one of these "locally..."
    Kudos Anthony & Rick - thanks!
    The Iron Mistress Galleries
    R.I.P. Dave...
    MAGFX is online now Nevermind my mind!
    Dec 2005
    Arizona
    A Decent Graphic and Numeric Tire and Wheel Calculator
    CHECK OUT THIS ONLINE TIRE/WHEEL CALCULATOR: http://www.bigcustomwheels.com/rt_specs.jsp
    Just fill out your existing tire/wheel info on the left, and then fill out your dream tire/wheel info on the right. Check out all of the calculated information below the graphics. It gives you a thorough comparison to your existing set-up. Take some of this information and compare it to your measured clearances between your tires and suspension uprights/wheel wells/shocks/outer fenders on your car. Always take into consideration that as the wheel (especially the rear) droops or moves up into the fender, some of those dimensions will change. This calculator sure helps out though. I have spent a lot of time going through many scenarios. The tough part is finding the actual sizes and offsets (et.) of the wheels. Tirerack.com is pretty good at giving the actual (or close to) section widths, etc. of tires from different brands.
    I also spent a lot of time measuring the tire clearances with the car in various attitudes to get the tire sucked up in the fender and drooped down. Note: the less the wheel is drooped (including lowering springs), the greater the clearance is on the inside of the rear. Also the closest inside clearance on the rear is the forward-inner part of the wheel well and not the upper-inner of the wheel well. The front suspension upright moves along with the wheel assembly. So what you see is what you get. Also, there is probably some lateral tire movement at the top of a tire as the bottom is pushing in a hard turn. This calculator is theoretical, so double check everything on your car.
    HAVE SOME FUN!
    Cheers…
    Silver1's Avatar
    Silver1 is offline disLXic
    Ketchum, Idaho
    Just a note on tire size. According to the Continental Tire website, the stock 225/60-18 tire has a diameter of 28.0" - NOT 28.6" as all the tire calculators tell you.
    "One must live the way one thinks or end up thinking the way one has lived."
    Scott is offline AWD Fan
    Dec 2004
    Wisconsin
    Quote Originally Posted by Silver1
    Hey Silver1,
    I puzzled about this myself, so I measured the circumference of a fresh set of stock tires and calculated the dia. I don't have the exact results at hand, but the measured size was close to 28.6". Continental's website is in error at this point.
    Scott
    Vaderwagon's Avatar
    Vaderwagon is offline LX Padiwan
    Marengo, Ohio
    Here is the one I use. Sorry if I posted this before.
    http://www.powerdog.com/tiresize.cgi
    Outside of a dog, a book is a mans best friend. Inside of a dog it's too dark to read. -Groucho Marx
    2005 Black Pearl Magnum RT
    Eibachs, SRT8 suspension, K&N CAI, SuperChips FP, Mopar hidden hitch, Blastin Bobs pipes, Kumho STX 255-55-18.
    ASU_Magnum's Avatar
    ASU_Magnum is offline I'll be back...someday
    Nov 2005
    Phoenix
    thats cool. from the stock 17" wheels i only went up .6" in diameter and .3 revolutions per second in going up to my 20"s which offsets my speedo by 1.5mph at 65. anyone know what the true speed would be if the speedo reads 80 then?
    2005 Magnum SXT Bright Silver - SOLD
    2006 Yamaha R6 Raven -STOLEN
    Quote Originally Posted by Zmagnum
    You are famous. You have the fat woman sittin' crack findin' Magnum
    GROUNDED's Avatar
    GROUNDED is offline My car is lower then your standards...
    Dec 2006
    wilbraham, ma
    Quote Originally Posted by Scott View Post
    Hey Silver1,
    Scott
    different brand tires measure different heights, just ask the 4x4 guys because they get it the worst in the bigger sizes.
    MattRobertson's Avatar
    Feb 2005
    At the bus stop...
    Quote Originally Posted by Vaderwagon View Post
    Thats my regular bookmark as well. No other calculator can do 2, 3 or 10 different sizes side-by-side like the Powerdog calculator can.
    But the bigcustomwheels one gives you offset, which is another unique thing. Not something you need every day, but a useful thing to have in your hip pocket.
    Big Boy's Avatar
    Big Boy is online now 2013 or Bust .....
    Feb 2006
    Columbia Ridge, OR
    Quote Originally Posted by 7thS0N View Post
    That might be this one.
    http://www.miata.net/garage/tirecalcold.html
    Just another choice.
    It looks like 2012 will be very good indeed.
    Unless the Mayans are right, then, well, never mind.
    joseph's Avatar
    joseph is offline Banned
    Oct 2004
    Las Vegas, NV
    This is the website I use all the time: http://www.1010tires.com/TireSizeCalculator.asp
