Results 1 to 15 of 21
Like Tree2Likes
Thread: How to polish aluminum brake calipers
    fnkycld's Avatar
    fnkycld is offline Yes that low without air bags.....
    Jun 2009
    Anaheim, CA
    So you want to polish your brake calipers. This easiest way to do this is if you have an extra set of calipers to work on without taking your car apart and not being able to drive it. In my case I was able to get a set of R/T calipers to work on so that I could replace my V6 brakes.
    This will take the good part of 1 day if not 2, depending on how detailed you want to get and the tools that you have access to.
    First thing, the list of tools needed to polish aluminum calipers.
    1. Air die grinder, (this can be done by hand if you do not have access to an air compressor, it just might take a little longer) an orbital sander can also be used
    2. Twist loc abrasive disc 40 grit, 100 grit, 150 grit
    3. Sandpaper
    • 220 grit
    • 320 grit wet/dry
    • 400 grit wet/dry
    • 600 grit wet/dry
    • 1000 grit wet/dry
    • 1500 grit wet/dry
    4. 6” bench buffer or grinder with a buffing wheel installed
    5. White aluminum oxide for general purpose buffing and Red rouge for high polish
    6. You will definitely get your hands dirty, you may want to get some mechanics gloves during the sanding and polishing. Also if you are using a bench buffer, you may want to get some thicker gloves as the caliper will heat up a little as it is being buffed and you don’t want to burn your hands or drop the caliper as it heats up.
    Now to get to work! If you have an extra set of calipers to work with, you will not need to remove the ones on the car, or you can work with them on the car instead. For this write up, I will give instructions on polishing calipers that are removed from the car already.
    Pictured below are the calipers before any work is done to them.
    1. First step is to clean the calipers from all grease, dirt and debris before you start your work.
    2. At this point you can prep and paint the caliper any color you would like and then start grinding and smoothing. This would be to fill in the grooves on the top of the caliper and to add a little personalization to them.
    3. Now that your calipers are cleaned of all debris, you can start grinding / sanding them down. I initially used a mini die grinder with 40 grit sanding disc to clean up the rough finish, grind down the casting line and remove the dimples that are on the front of the caliper.
    Pictured below are the calipers after disc sanding and removing the casting line and dimples.
    4. Now that you have the casting line removed and the dimples are gone, you can continue using 100 grit sanding disc and then 150 grit sanding disc to start to remove any of the previous grinding marks and begin the smoothing process.
    The next process is the most time consuming of the most important to get a nice clean mirror polish
    5. Begin by using 220 dry sandpaper to remove the last of the grinding marks
    The calipers below are sanded using 220 grit sandpaper to begin removing the grinding marks.
    6. Now is when you want to start using the 320 grit wet/dry sandpaper and wet sand the calipers. At this point you will want to start cross sanding by sanding in one direction and then using the next higher grit sandpaper in the opposite direction to smooth out any imperfections
    7. After you start in one direction with 320 grit move on to 400 grit, 600 grit, 1000 grit and then 1500 grit
    Pictured below are the calipers after wet sanding
    8. Now you should be looking at a caliper that is almost shiny, but not polished yet. This is where the bench buffer comes into play. If you do not have a bench buffer, you can use a small buffing wheel on a high speed drill or start to polish with polishing compound by hand.
    9. You can use the white polishing compound bar and dress the buffing wheel before you run the caliper on the wheel to begin the shining process.
    10. Once you have an initial shine, you can use the red rouge on a new buffing wheel as you do not want to use the same wheel for 2 different compounds.
    Below you see the top caliper that has been polished with the red rouge and the bottom caliper has been wet sanded and ready to polish
    Here are my stock V6 brakes before I replaced them
    Here are the R/T Calipers and drilled/slotted rotors installed
    11. Now that this step is done and you have achieved a shine that is satisfactory, you are done and ready to mount your shiny calipers back on your ride.
    Here are the polished calipers with the wheel mounted. They really stand out now vs the stock V6 calipers. Plus the braking is greatly improved.
    Good luck to all. Any questions, let me know.
    Need a tire calculator? Use this one.
    Plenty more pics on my Facebook page
    hackit is offline LX Newbie
    Sep 2008
    Welland, Ontario
    hey i love your idea,
    i have a v6 as well and was told the rt rotors and calipers wont fit. I see you said thats what you are using, can you explain what you had to do to get them to fit.
    Thanks, now i want my calipers looking like this, better than red.
    Magnum P.I's Avatar
    Magnum P.I is online now WTF is that?! Let's call it a 300Wagon..
    Jan 2008
    LX & LC Nation, Brampton, Ontario
    Oh man that is one sweet mod and a excellent write up, and the first thing i will do next spring unless i can find a second set of clipers to work on...
    06 SXT AWD Magnum, Silver Steele Metallic: Chrysler's Red headed stepchild!!!
    I drive mine like I just left the bank after an unapproved forced permanent loan ...
    fnkycld's Avatar
    Jun 2009
    Anaheim, CA
    Quote Originally Posted by hackit View Post
    Yes I did use R/T calipers. As you can see from the before and after pics, the rotor is bigger as are the calipers. Once you take the 2 calipers bolts off there are 2 bolts holding the calipers bracket to the spindle. Remove those, slide the rotor off the hub and then put the R/T stuff on and switch your brake lines. don't forget to bleed the brakes. Easy to do. The braking is greatly improved as well.
    fnkycld's Avatar
    Jun 2009
    Anaheim, CA
    Quote Originally Posted by Magnum P.I View Post
    Thanks Magnum, If you can find a second set of calipers, it is so much easier. You do not have to rush the job and can take your time getting the shine that you want instead of trying to hurry it so that you can drive your car again.
    Motor's Avatar
    Motor is offline pwrparts.com | Eric von Motor
    Chicago, Illinois
    That is nice...i want that done before i paint mine...
    RIP - 05 Dodge 'Dirty Whore' Magnum R/T (12/7/11)
    Current - 11 Ford 'Whorus' Taurus Limited - a step back from modding
    Redfox0099's Avatar
    San Antonio, Tx
    Quote Originally Posted by Motor View Post
    Wouldn't Powder Coating last longer and be more resistant to damage than paint?
    Motor's Avatar
    Chicago, Illinois
    yeah...but its a dd...i cant have my car down for long...and with different stages of duplicor (self edging primer, etc) i should be good
    scoot13's Avatar
    scoot13 is online now #Indulge #Luxury
    Vegas
    concussion's Avatar
    concussion is offline So that's what mid 11s look like....
    Charlotte, NC
    I've polished my calipers as well. I still need to get the final polish on the fronts. It's a ton of work.
    http://www.cardomain.com/ride/3247903
    The Old: Stock 5.7 Bottom End | Lead Foot | 11.861 @ 112.76 1.63 60'
    The New
    : Forged Arrington 6.1 | MMPG Top End | Paramount Drivetrain | 11.67
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    I have a set of front R/T OEM calipers that are already powder coated in gloss black if you wish to purchase them..
    as the pistons are removed for the powdercoating process, they need a piston rebuild kit (part number 5137665AA x 2 (comes with 2 pistons, rings and boots in each kit so you need one for each side of car)) $35 each from www.moparpartz.com
    I paid $250 for the powder, so i'll sell them for that price plus shippng.
    I had these done last year before the WilWood Group Buy, so I never used them after getting them powered.
    Sep 2008
    Welland, Ontario
    Quote Originally Posted by fnkycld View Post
    What part of the brake lines do you have to change?
    also is it as easy as just removing the old calipers and rotor and replace with the rt rotor and calipers? or would i need to buy some kind of adapter?
    Thanks
    fnkycld's Avatar
    Jun 2009
    Anaheim, CA
    Thanks
    Yes it is as easy as it sounds. The parts you will need are the caliper, the caliper mounting bracket and the rotor. The bolts that hold the mounting bracket on are the same. You just remove the caliper, the mounting bracket and then the rotor. As for the brake lines, you will need to move your existing brake line on the the new caliper. In doing so, you will introduce air into the system and will need to bleed them to make sure that there is no air in the lines.
    Sharma's Avatar
    Sharma is offline Sharma Racing
    Dec 2006
    San Jose, CA 95126
    bigal470 is offline LX Guru
    Nov 2006
    San Marcos, CA
    NICE JOB!!! I did it on the car pretty much polished the face painted the backs turned out good
    New Ride In the Making! Like it on the Book and watch the build progress
