Page 1 of 7 123 ... LastLast
Results 1 to 15 of 100
    DMAG's Avatar
    Feb 2004
    New Yawk
    How-To Install Lowering Springs
    compiled by snickle
    Dodge Magnum SXT with 245/40-20 tires
    Before picture:
    1st step is to jack the car, support on jack stands and remove wheels:
    Fronts:
    Remove the upper sway bar link:
    Then remove the bolt securing the upper A-arm and separate it with a pickle fork:
    Tie the upper arm with a string for now, so as to keep the brake line from stretching:
    Remove the top 3 shock mounting bolts, but leave one lightly attached to hold it in place, (also remove the lower shock mount, but its not pictured):
    Remove the strut assembly as a whole, then use your spring compressor to tighten the springs for removal:
    Old and new springs:
    New spring reassembled:
    Reassemble in reverse order of disassembly.
    Anthony
    DMAG's Avatar
    Feb 2004
    New Yawk
    Rears:
    Remove the rear shock, it is held on by one nut/bolt on the bottom and two bolts on top:
    Next remove the inner part of the lower control arm. Set a floor jack under to keep the spring from expanding and knocking the whole assembly loose when you remove the bolt
    Here is the inner arm removed:
    For info, a pic of the top of the shock, installed:
    Rear spring comparison:
    The rear spring is removed by gently releasing the jack holding the arm up. then place the new spring in its place.
    Next, we need to disassemble the rear shocks to trim the bumpstops (not necessary on fronts)
    Before:
    Bump stop after:
    Once again, reassemble everything in reverse and you are done!!!!
    After picture:
    Torque Specs from Badpenny:
    FRONT
    1) shock shaft: hold the shaft from turning, tighten retaining nut to 66 ft. lbs. (there is a special tool 9362 for this).
    2) upper ball joint: hold stud from turning, tighten nut to 35 ft. lbs. +90 degrees.
    3) stabilizer link: hold stud from turning, tighten nut to 108 ft. lbs.
    4) lower shock mounting bolt: tighten to 128 ft. lbs. with car on ground at ride height.
    REAR
    1) spring link bolt at crossmember: tighten nut to 80 ft. lbs.
    2) shock absorber upper: tighten bolts to 38 ft. lbs
    3) shock absorber lower: tighten nut to 53 ft.lbs. with car on ground at ride height.
    Anthony
    SoCalRT's Avatar
    SoCalRT is offline Major Mag Nut
    Lake Elsinore, CA
    Exclamation Alternative to the Pickle Fork
    You may want to use a tie rod end puller instead of the pickle fork. I picked up this one for around $10 at the local parts store. A few turns with a wrench and it popped loose, with no damage to the rubber seals.
    Later,
    Brett
    Vaderwagon's Avatar
    Vaderwagon is offline LX Padiwan
    Marengo, Ohio
    What happened to the pics of the "lowering spring" install?? The description is good but the pics are helpful.
    2003z is offline LX Padiwan
    Jul 2004
    sorry, i switched ISPs, then my computer crashed and I lost all my pics.
    2005 Dodge Magnum SXT
    2005 C6
    ChargerOsix's Avatar
    ChargerOsix is offline Supporting Vendor
    DF-DUB
    Quote Originally Posted by t5rwagon
    On each box, right click and goto Properties. Cut and past the URL and replace dodgemagnumclub with lxforums. The pics are in order so just replace the number for the next frame.
    DMAG's Avatar
    Feb 2004
    New Yawk
    Sorry...fixed the pics in the posts.
    Anthony
    Black on Black's Avatar
    Black on Black is offline and there's no going back
    Chicagoland
    I used the same tool and it worked out great. Those rubber seals/gaskets are filled with grease, so its always nice when you can do without damaging them.
    Quote Originally Posted by SoCalRT
    '05 Dodge Magnum R/T - Brilliant Black Pearlcoat - SOLD
    '05 Pontiac GTO - Cyclone Gray M6 - "CycloneLS2" at ls2gto.com
    StatueMan is offline LX Newbie
    May 2005
    RE: Lowering springs and bump stop
    DMAG
    Does the "bump stop" require trimming or is it something you did for ride, etc? What if it isn't done? What did you trim it with?
    Quote Originally Posted by DMAG
    Jerry M.'s Avatar
    Jerry M. is offline LX Newbie
    Feb 2005
    alignment
    Is an alignment needed after installing the lowering springs?
    snickle's Avatar
    snickle is offline LX Old Timer
    May 2004
    An alignment is recommended, however that can be challenging as it won't quite come to factory spec. Camber is off.
    2005 Dodge Magnum RT - Midnight Blue Pearl
    Volant CAI, 190 Thermo, Mr. Grille Vertical Grille,
    SXT Headlights, MDS Monitor, Bel 975R,
    Infinity 3002cf (dash),Blaupunkt 605 woofer (door), Infinity 6002si (Rear),Infinity Basslink, SC Tuner, GSM Fan/Traction Mod, 22elite Heal Guard, Factory One Tail lights
    buellcyclone is offline Silver RT
    Double Oak, Texas just north of Dallas
    I just installed a pro kit last week. In an RT you have to loosen your exhaust to remove the inner A arm bolts so remember that. That took a little time. Use a impact driver to remove the bolts from the shock shafts, forget about the special tool Chyrsler says you need for the struts. Ensure that the spring compressor is compressing the springs slightly before you remove the spring holder on the strut to make sure the spring doesnt fly when you remove the holder. You do have to remove and cut the rear suspension stops or you will continuously bottom out.
    When you installed your kit does your front suspension bottom out occasionally? Mine does. Just wondering. Also, do you find the ride a lot harsher? I installed a Pro kit on my 2000 Mustang GT and the ride didnt feel too much harsher but on the Magnum, I really feel the length of the car now compared to stock springs and the ride is way more rough.Let me know.
    Thanks
    nkjs77 is offline LX Newbie
    Very helpful. Thanks alot~!!!
    Earache is offline LX Newbie
    May 2005
    Although mechanically challenged, I am swapping out my RT suspension bits for SRT8.
    Removing the spring\shock assembly is straightforward, but I am stuck on how to remove the top hat from the assembly. The retaining nut is recessed into the hat and compressing the spring does not make it accessable.
    How do I get to the 18mm retaining nut in order to remove the hat?
    earache
    ______________
    2005 Midnight Blue RT
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Quote Originally Posted by Earache
    earache
    ______________
    If you dont have the tools do yourself a favor and take the strut assemblies to a shop.They will swap them out quickly and for just a few bucks.Otherwise;put your spring compressor on and tighten down on the spring to take the tension off the hat(NEVER TAKE A STRUT APART WITHOUT A SPRING COMPRESSOR!IT IS THE FASTEST WAY TO LOSE BODY PARTS!)Then you will need a thinwall 18mm impact socket and impact gun.Spin the 18mm nut off take the hat off,replace the spring and put the hat back on.Put the nut bak on and spin it down with the impact gun.Then you can let the spring compressor off the old spring SLOWLY.I found that you do not need the compressor for the new spring as it's short enough to put the hat on without.
    BFNY PERFORMANCE
    RIP My Friend
