If you change tire size on your car, you need to get someone with a starscan to select a tire as close to the size you have as possible. Unfortunately, the list is limited (as you will see in a minute). Hopefully in a future version of the software DC will decide to go to a larger list or just have you input the tire size.
From the main menu, select "Vehicle Preparation"
Scroll down to the selection called "Program Tire Size"
Select it by touching this selection and then pressing the Start button. Wait until you see how weird this procedure is, makes me wonder if DC engineers have a sense of humor.
Click next to continue:
A window will appear showing the current tire size selected. Click next to continue:
The next couple of pics are just to show you what is available for selection.
Select the tire that is closest to what you have and click next.
Another message window will come up.
Yeah, I know, I selected continental tires. I was hoping you didn't notice. LOL!
Click next to continue. Here is where it starts to get weird.
Cycle the ignition key off then on again. OK! As soon as you do that this window appears:
At this point the starscan is writing the info to the controller. After a few seconds guess what window comes back?? Yup, time to cycle the key again.
Once you do another window appears letting you know the operation was a success. Odd huh??
Click finish and you are done. It does set a few DTC's and here are the ones that were set during this operation on my car.
Dealer can just click clear all dtc's and they go away. It is from cycling the key off and on.
That is it, your new tire size is programmed into the computer.
