Can bus network overview screen
From the main screen seen below select Network view:
When you do, a very detailed image of the bus layout is displayed. The items that are not blue in color are items that could be configured but are not available in this vehicle.
I will post a list of acronyms that should make this view a bit easier to understand. It will be under the starscan section of the knowledgebase. From this view, you can easily move from one module to another by simple touching the screen. This is just a different way to navigate the system.
2005 Dodge Magnum R/T
-Martin Luther King, Jr.
