Results 1 to 11 of 11
    Killswitch is offline LX Newbie
    Mar 2009
    What 17" wheels fit 09 Challenger R/T
    I want to mount my 17" M/T ET street slicks, but can't find or don't know what wheel to use. I tried a set of Ford factory cobra rims, but the offset is causing the rim to hit the sway bar. I read here somewhere that these rims fit. Is anyone using 17"x8" wheels? I don't care what they look like and cheaper the better. I just want to run these tires. Thanks
    slideway's Avatar
    slideway is offline Onward, through the fog
    Jun 2007
    Union co. N.J.
    The wheel's do touch the sway bar when jacked up but lower the car and the susp. move's it in so it clears, Try it again and lower it to check.
    Mar 2009
    Really!!!?? I had it on the lift so the suspension was hanging. I'll try to jack it under the lower a-arm and try again. Thanks Slideway. This will make my day if it works!
    slideway's Avatar
    Jun 2007
    Union co. N.J.
    Quote Originally Posted by Killswitch View Post
    Yeah, that's what my cobra replica's did. For a nano sec. I was gonna freak till I remembered reading about that here! lol
    Mike V. is offline LX Newbie
    Aug 2008
    I use 17x9 Cragar Soft 8s with a 5" back space. They clear and work
    perfectly.
    Mike
    2009 Challenger R/T 6-speed... bone stock other than a set of 17x9 steelies with some sticky tires.
    Best MPG: 32.7 - Hyper-miling a Challenger R/T is quite odd.
    Dodgetony's Avatar
    Dodgetony is offline LX Padiwan
    Jan 2009
    Ohio
    I use American Racing torque Thrust M's. 17 by 9...6" backspacing. They are close to the rear sway but clear.
    09 Challenger RT Auto: port matched shorty headers, catless mids, Magnaflow catback, home ported TB, 180 stat, modified stock air intake, M&H DR's, Predator with DCX Depot CMR.
    12.441 @ 110+ NA
    11.69 @ 115+ 100 ZEX
    Mar 2009
    What do you mean by "Backspace"? Is that neg offset?
    Dodgetony's Avatar
    Jan 2009
    Ohio
    I am not sure what you mean by negative offset....but I think you are on track with that.
    It is the amount of the rim that extends back from the mounting side of the wheel on the hub (the side you don't see).
    12.441 @ 110+ NA
    novawagonmaster's Avatar
    novawagonmaster is online now Motivated by cake.
    Jan 2009
    Ashtabula, Ohio
    Wheel on the left looks to be about "zero offset". Wheel on the right is "negative offset". A wheel off a front wheel drive has "positive offset". It references the mounting flange in relation to one-half the wheels width (center).
    Mar 2009
    Thanks guys, I know offset. Backspace is easier to deal with, but I haven't noticed many wheel manufactures referencing backspace. They should IMHO.
    RT NOMAD's Avatar
    RT NOMAD is offline Mopar Rules
    Jacksonville, FL
    The good thing about backspace is that it doesn't change with the width of the wheel.
    But the horrid offset changes the backspace (which is usually the important dimension) as the width of the wheel changes.
    My Enkei 18x9's with a +18mm offset has a backspace of 5.2 inches,
    Yet my Enkei 17x10's with a +18 offset has a backspace of 5.7 inches.
    Terry
    2011 Charger SE (blackberry)
    2011 Ford Raptor
