Results 1 to 13 of 13
Thread: VVT or VCT?????
    Challenging Times's Avatar
    Challenging Times is offline CF-----Salem, Oregon
    Jun 2009
    Near Salem, Oregon
    VVT or VCT?????
    Ok, here's a question about the 5.7l... With the 6 spd manual trans, my Challenger does not have the MDS. Does this mean its the VVT and not the VCT? What are the major differences between the 2 other than a bit of chamber size?
    Salem, Oregon CF... Gotta love those Mopars!!!!!
    Tbird100636's Avatar
    Braintree, Massachusetts
    Cool
    Quote Originally Posted by Challenging Times View Post
    Variable Cam Timing (VCT) is another name for Variable Valve Timing (VVT).
    www.ramtruckforums.com
    Jun 2009
    Near Salem, Oregon
    Quote Originally Posted by Tbird100636 View Post
    So, if VVT is VCT, then why the 2 different terms? Checked my window sticker... Mine is VVT... So, its also VCT? I'll have to do more research i guess.. Thaks for the response!
    Mymopar's Avatar
    Mymopar is offline Punishing the competition
    New England - CT
    I think the difference is in the way it works. With the VCT it works by having a "special" cam sprocket attached to the intake cam. This sprocket is actuated by oil pressure by a solenoid that regulates the advance or retard of the cam. This sprocket also costs big $$$$ to replace.
    Knowing this perhaps VCT is for dual cam cars.
    VVT perhaps is for single cam cars that operate on a different principal that I am not completely familiar with so I won't go into it.
    392 Modern Muscle Stroker, 3.06 rear, 2800 stall, Fri Stage 3 heads, ported TB, SLP long tubes, SLP underdrive pulley, Silver Box, TZ Chally hood, custom BT, KW V2 Coilovers, Hotchkis sways and custom fabbed End Links
    1969 (oo===]|[===oo) 1973 (oo /=====\ oo)
    1998 (O|||||||O) 2006 (Oo.|==+==|.oO)
    ARoss's Avatar
    ARoss is offline LX Newbie
    Brandon, FL
    VVT is Variable Valve Timing. VCT is Variable Cam Timing. The Hemi's have VCT. It's two different methods to achieve the same results. You'll mostly see VVT on overhead cam engines like on a Honda, Toyota or Nissan. Most cam-in-block engines have VCT.
    2005 Magnum RT | Midnight Blue | SRT8 Suspension | SRT8 Wheels | General Exclaim UHP 245/45/20's | Carbon Fiber Air Hammer | Magnaflow exhaust
    gr8crash is offline LX Degenerate
    Apple Valley, CA
    I thought it had to do with the MDS function. Since MDS isn't on the manual cars it was VVT i think? Figured it was just 2 diff methods to end up with the same result of power, mpg etc
    Jun 2009
    Near Salem, Oregon
    Quote Originally Posted by ARoss View Post
    Uh, sorry, my hemi is VVT... Right off of the window sticker...
    Steve HR Hooligan's Avatar
    Steve HR Hooligan is offline All out of money for upgrades
    Mar 2009
    Whitby, Ontario
    Mine has VCT due to the way the MDS works. The 6 speed cars do not have MDS only the autos. Here is the link to this kool site that explains in detail how the MDS works.
    http://www.moparmusclemagazine.com/t.../photo_01.html
    Steve Hot Rod Hooligan
    Hemi registration # 1132
    stevesrt8 is offline long term car nut
    Feb 2006
    sunny florida
    facts
    variable cam timing IS variable valve timing.
    VCT is VVT. Since the rotation of the cam relative to the crank is changed, the timing of the valve events is also.
    The new Eagle is a winner!
    Steve
    06 300C SRT8
    Mymopar's Avatar
    New England - CT
    Quote Originally Posted by stevesrt8 View Post
    VCT is VVT. Since the rotation of the cam relative to the crank is changed, the timing and duration of the valve events is also.
    True but I think they use a different means to achieve the same end result.
    The Mazda's are VCT, a special cam sprocket is used on the intake cam (dual overhead cam). The exhaust cam is unaffected by the VCT, it always rotates teh same n omatter what.
    Now having only one cam for the Hemi, I don't see how it can be the same method as VCT.
    I think we are interested in figuring out how the VVT works.
    Alfa Charger's Avatar
    Alfa Charger is offline LX Padiwan
    Nov 2005
    Blackstone, MA
    I think (not 100% sure) that duration and valve events are not changed on the Hemi, only the timing.
    VVT and VCT are different names for the same thing. Since VVT was invented by Fiat, Chrysler can call it VVT now!
    2006 Dodge Charger R/T, My Winter fun car.
    1987 Alfa Romeo Spider Quadrifoglio, My rest of the seasons fun car.
    Feb 2006
    sunny florida
    corrected.
    the duration will not change, hence my edit.
    Chrysler moves the cam drive with an elegant sprocket design. Honda switches lobes completely by moving a follower over. BMW has some engines with no cam at all! They control the valve directly with a HS solenoid.
    All different means to the same end.
    Steve
    06 300C SRT8
    lieu910 is offline LX Padiwan
    I don't know that elegant is the word I would choose. This sproket design for VCT has been around for some time and has been used by Mazda, Ford, and GM.
    The system has had it's share of failures and problems accross the board.
    You guys will quickly learn that cam or valve spring changes will result in big VCT headaches.
    I can tell you on the Ford side, the 3V Mustang uses the same VCT system and most guys changing cams and springs use a VCT limiter or a complete VCT lockout.
    I use limiters in my S197 that limit travel to 20 degrees as opposed to the factory 60 degrees. This prevents a piston to valve collision.
