Today I installed my new Magnaflow catback exhaust on my Challenger SRT. My friend Shannon who owns Redline Gaugeworks offered his shop up for the installation. He has a lift which makes this install much easier, but it has been done in people's driveways on jackstands as well. The guys from Magnaflow came down and brought my exhaust and stayed for the entire install process documenting the installation with pics. Each step was shot and a step by step tech article will be written up by Mopar Enthusiast Magazine in a future issue.
I had just recently found out that Magnaflow has two different systems available for the SRT. One is their regular catback and the other is a louder set up and I think they call it their "Competition" system. When asked which set up I wanted to go with I opted for the competition system because it's supposed to be a more free flowing set up and also a bit louder. I have previous experience with a Magnaflow catback on my wife's '07 Charger R/T and though I was definitely pleased with it, I always wished it could have been just a bit louder, so I was excited to hear that they have the two different options for the SRT.
The installation was straightforward. I have done exhaust swaps on at least 5 of these LX cars already, so it was nothing new to me. The only surprising thing was that Chrysler obviously did away with the center cross brace that is right in the middle of the LX cars. It is right under the exhaust and if you didn't make sure the center of your exhaust is tucked up enough and has enough clearance, you would have a nasty vibration. I was glad to see the brace gone on the Challenger.
Now for the install:
Below you can see the Magnaflow van as they are showing up with the goodies.
Below is the box with the kit inside.
Here you can see the entire kit laid out ready to install. All pieces necessary for the installation are included in this kit. There is no need for any welding.
Here's the car before the install.
First thing we did was spray some lube on all the bolts to help loosen them up. We also sprayed WD40 on the exhaust hangars rubber grommets to make it easier to slide them off. That's my boy Shannon doing the spraying.
When you begin, just go down the exhaust and loosen all the bolts, remove the drivers side pipe from the center back, and then remove the rest of the entire exhaust system in one piece.
Here's the entire factory exhaust removed. Replacing this will net you considerable savings in weight, not to mention better flow and sound qualities.
Here's a shot under the car with the stock exhaust removed completely.
We began installing the Magnaflow exhaust from the front back. We tightened the clamps as we went but we left some play in them so we could make any adjustments to straighten the length and exit of the exhaust if necessary.
This is the first two sections of the Magnaflow kit coming together.
The clamps are very good, and do a sufficient job of sealing the pipes.
Here's a look at the inside of the mufflers.
This is my boy Shannon tightening up the last bolt on the final sections of the exhaust. The drivers side and passenger side exhaust pipes are installed separately, as opposed to the factory system that has the passenger side welded to the system.
As you can see, I opted to go with Magnaflow's quad exhaust tip set up. I think it looks pretty cool. It's different, and I can always go back to the stock tips if I ever want that stock look again.
When I cranked the car up for the first time, I was very pleased. The car has a deep rumble at idle, and it's just loud enough at idle to let you know there's something there. When you step on the gas, there's no doubt that you're driving a Hemi! This thing sounds NASTY in a good way! I really love the way it sounds in all driving conditions...idle, acceleration, and deceleration are all satisfying. There's no flutter, just a smooth muscular sound throughout the powerband. I've only had it on the car for half the day, so I can't say for sure about drone, but I am going to wait for a month or so to let the system settle in and season a bit and then we'll see how it acts. I must admit, I'm a guy who likes to hear my car run. A lot of the time I find myself with the radio off just listening to that Hemi sing. This may be too loud for some people, and not loud enough for others. If you're not sure, check out both of their systems. I feel like between the two set ups, there's something for everyone.
If you're looking into an exhaust for your car, I would give Magnaflow a strong consideration. Everything is top notch quality and my experience with their staff has been great. They also guarantee that their systems increase performance and horsepower. Those are all important aspects to consider when purchasing an exhaust for your car.
