Results 1 to 7 of 7
    Hemi Challenger is offline LX Padiwan
    Jan 2009
    Fort Lauderdale
    JBA Shorty and Mid Hi Flow Cats anyone?
    Has any one here put on a set of JBA Shorty headers and the Hi Flow Cats and mid pipes on there 09 Challenger RT 5.7 car? Want would you estimate the added HP to the rear wheels would be with this add on setup?
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Unless JBA revised the design of the shorty they will not fit the 09' heads.You guys have the same exhaust port as the 6.1.so either run a 6.1 long tube or a stock 6.1 header.....which is a true shortie in the clamshell.....you should pick up 10-15 hp.
    Posted via LXFMobile
    Crazy R/T's Avatar
    Crazy R/T is offline previously Black R/T 06
    Feb 2006
    South shore of Montreal, Canada
    HHP has some new ones listed. Part# 1964S-1.
    06 Magnum R/T brillant black
    , JBA headers/mid-pipes, C&L CAI, Predator CAI 91 tune, BT pistol grip, Kicker audio upgrade, MSRT wheels
    Challenger370 is offline 2010 Challenger R/T DWB sig 4 mods list
    Sep 2007
    Indiana
    Im curious to about hp #'s, each seperatly are rated at about 9, but typically when you combine mods you dont get the sum of each seperatly installed.
    07 3.5L Charger K&N CAI, Magnaflow Cat back, JBA shorty's, DiabloSport 93 tune sold, 2010 Challenger R/T 5 speed. 180 degree Thermostat with fan settings lowered, CC, ceramic brake pads, slotted rotors, red and black caliper paint, Challenger label for calipers, Corsa Cat back, functional hood ducts, and hood struts, 93 custome DiabloSport tune, Mopar drop in filter, JBA Shorty's, Wideband O2, anti-sway bars front and rear, end links, and strut brace.
    Grey Ghost's Avatar
    Grey Ghost is offline LX Padiwan
    May 2009
    Oregon
    Quote Originally Posted by Challenger370 View Post
    I just installed the new “D”Port JBA shories yesterday and did a dyno tune. I had the high flow cats from HHP on it already, but have a baseline from before they were installed. Combined I picked up 15hp, and 42tq at the rear wheels.
    Jan 2009
    Fort Lauderdale
    JBA Shorty's
    Quote Originally Posted by Grey Ghost View Post
    Was it a big job installing your JBA Shorty's? Any tricks or snags to know before starting and how did your 02's fit on them? Plus did you SHUT off your Rear 02's through your Diablo? Thank you for the info.
    Grey Ghost's Avatar
    May 2009
    Oregon
    Quote Originally Posted by Hemi Challenger View Post
    I had a shop do the work, but it looked pretty straight forward. They didn't seem to have any problems, and did most of the job from under the car. Personally, I would not take on this job without a lift though, but one could do it without if needed, I think. All my 02 sensors are on. The headers and cats have bungs in them for the sensors.
