Results 1 to 13 of 13
    ajhagerman is offline LX Newbie
    Mar 2008
    Factory hood to fender stripe? Remove?
    I thought I should start my own thread instead of asking in the other. Can these stripes be removed? I only assume that they are not cleared over. The reason, I have found a car I like, however it has these stripes - and I dont care for them.
    gameover's Avatar
    gameover is offline voiding warranties
    May 2006
    New Orleans
    I pretty sure its vinyl. I seen a challenger with the black matte on the hood removed.
    05 RT . Jett Black . SRT Fascias . UAS . AFEII . Zoomers . Forgiatos . Wilwoods ...
    lupoman's Avatar
    lupoman is offline CHALLENGER NEWBIE
    Sep 2008
    OAHU
    am sure a paint shop can remove them no problem, as long as the car is still very new (Sunbleach on the paint etc).
    Being vinyl and all, probably just a heat gun.
    A Work in Progress- http://www.cardomain.com/ride/3227362 (my car domain)
    Rt's RT's Avatar
    Rt's RT is offline Rhodesian Ridgeback chaffuer
    NY/CT
    If it's like the SRT the stripes are done well after paint (and everything else for that matter) at a seperate vendor 5 hours away from production so I doubt they're cleared over.
    I would think a heat gun and a good buffing after should do the trick.
    gn300's Avatar
    gn300 is offline Tipmaster G
    Nov 2004
    Nova Scotia canada # 1313
    Have the dealer take then off as part of the deal!
    karfreek's Avatar
    karfreek is offline LX Guru
    May 2006
    Fultonville NY (Upstate)
    I looked at an RT with them today, they are NOT cleared over..
    Jay
    2011 Dodge Challenger R/T Classic - Redline 3-Coat Pearl, 6-speed
    2005 Dodge Magnum RT-Can you say...HEMI?
    2004 Chrysler Pacifica AWD-Everything but the kitchen sink.
    lupoman's Avatar
    Sep 2008
    OAHU
    Quick question- Are they flat black or semi or gloss black?
    karfreek's Avatar
    May 2006
    Quote Originally Posted by lupoman View Post
    The ones I saw were on a Black Challenger. The stripes were a flat charcoal/dark grey color. They looked great.
    Jay
    Fargo59's Avatar
    the stripes are done in a facility in windsor, across from detroit. the cars are built in brampton, ON. thats 4 hours apart, and you know they sit in a holding lot at both locations for probably a week each. the paint is well dried by then as the car is painted, then assembled. the stripes will come off, just make sure you have a competent shop do it, and there wont be any issues with marks, or lines, or pulling of paint.
    lowriderman3's Avatar
    lowriderman3 is offline Rut Ro!
    Low Down Dirty South!
    Clean it up man! Props for taking them off!
    Mar 2008
    Thanks for the responses guys, I will try to get them to make it part of the deal.
    Hal H's Avatar
    Hal H is offline 2009 R/T 6-speed - on order
    Sep 2008
    Portland, OR
    removing stripes
    the safest way to remove is use a hair blow dryer.
    Heat guns put out A LOT of heat (even at low setting) and you could potentially discolor or "cook" the paint. Even on the low setting a heat gun is designed to remove paint, or old window glazing compound.
    You would want to warm the tape stripes up gradually to soften the adhesive, and peel back slowly, then clean residue off the paint and probably polish & way the newly uncovered area.
    2009 R/T - on order 7/17/08
    Magnet is offline LX Padiwan
    Stripes
    If you can take your finger nail and catch the edge of the stripe. These are not clear coated. If they feel flush to the paint then it has clear coat over them.
    As far as taking them off. As noted a heat gun/hair dryer should do the trick and I use Goop Gone to remove excess adhesive.
    Magnet
