Results 1 to 4 of 4
    NYEREPAIR is offline Icemanmyk
    Mar 2009
    Tempe
    5.7 Hemi Mopar cold air intake
    Ok, so I just installed the Mopar cold air intake. I have a bump in the road. The instructions tell em to leave the old IAT sensor in place. Later it tells me to insert the IAT sensor into the new intake tubing grommet. Where does this IAT sensor come from? Do i remove just the sensor, or the entire unit from the old unit? What gives here?
    After typing this, I did lube the grommet and find a way to get the old one in there, up to the blue O ring. Let me know if this is correct...Thanks,
    Mike
    Steve HR Hooligan's Avatar
    Steve HR Hooligan is offline All out of money for upgrades
    Mar 2009
    Whitby, Ontario
    yup, you have to make sure it is in the same postion as it was in the original unit.
    Steve Hot Rod Hooligan
    Hemi registration # 1132
    dchemi's Avatar
    dchemi is offline LX Enthusiast
    Rochester, NY
    Just plug it in to the new tube.
    2005 Cool Vanilla Magnum RT (Mopar CAI)
    Dose is offline Maggie 357
    Mar 2009
    Atlanta
    You remove the sensor from the old unit, install the grommet, then slide the sensor into the grommet, then connect the plug to the sensor
    I have the Need....the Need For Speed.
