Results 1 to 15 of 19
    1MOTOR42's Avatar
    1MOTOR42 is offline LX Newbie
    Nov 2008
    1-4 Skip Shift remedy....
    for all the current a future 6 speed owners, I have located a remedy to that PITA 1-4 Skip Shift that is strangling our 6 speeds... all in the name of "improved fuel economy"...
    Ebay has them under Item # 160295408981 for about $20.00
    Revmarc's Avatar
    Revmarc is offline Faster Pastor
    Oct 2008
    Greer, SC
    Yeah, I bought mine from speedinc.com for 18.99. Money well spent!
    2009 Dodge Challenger R/T 6-speed, Go-wing, Mopar CAI, custom tune, SRT chin spoiler and brake ducts, Mopar coilovers, custom mid-pipes and Magnaflow exhaust, 20" staggered Vipers
    2008 Charger R/T Road and Track package, SRT suspension, custom exhaust, Diablosport tune, Mopar CAI, sometimes the Vipers (wife and I swap wheels from time to time to be fair :D)
    EXTREME's Avatar
    EXTREME is offline Yes, that is my fast driving award.
    Oct 2005
    Flowood, MS
    lol that didn't take long to get to the market!
    US Wheels - Frank Racing - AirHammer - Corsa - AirLift
    22Elite - Billet Tech - 3B Spec HIDs - Diablo Sport
    JT/NoESP - Llumar - Stealth Auto - NavHack
    12.69 @ 109.65
    fnkychkn's Avatar
    greasy cardboard box
    good find.
    for those who don't know:
    DESCRIPTION
    The skip shift solenoid (1) prevents the operator from shifting into second or third gear during part throttle operation. The solenoid is threaded into the left side of the transmission case.
    OPERATION
    The PCM controls the skip shift solenoid, locking out second and third gear when all of the following conditions are met:
    • Engine coolant exceeds 41°C (106°F)
    • Vehicle speed is between 12 and 20 MPH
    • Engine operating above 1322 RPM
    • The PCM verified first gear speed/RPM
    • Throttle position sensor (TPS) signal is less than 0.68 volt above closed throttle (23 percent throttle opening)
    The solenoid resets when vehicle speed drops below 3 MPH.
    1fastsedan's Avatar
    1fastsedan is online now Warranties are for sissies.
    almost Mexico, CA
    Wow. First I've heard of this. That sucks that you buy a 6 speed and it's functionally a 4 speed.
    mexi's Avatar
    mexi is offline thats my sippy cup!
    Feb 2006
    N Misssisspi . Memphis TN
    wow thats some bs right there.
    mopar 11
    Corsa Hotchkis ...so far.
    crazy_luck's Avatar
    crazy_luck is offline I know where Hoffa is...
    Belle Plaine, MN
    Quote Originally Posted by 1fastsedan View Post
    Nothing new about it - my buddies '94 Z28 Camaro has this feature, and it annoys the hell out of him...
    EXTREME's Avatar
    Oct 2005
    Flowood, MS
    yup, GM has been using this for a while!
    crazy beat me to it!
    12.69 @ 109.65
    Revmarc's Avatar
    Oct 2008
    Greer, SC
    Yep, this is the third skip shift eliminator I've bought. The other two were for 6-speed Z28s.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    So what does it do??.
    stevesrt8 is offline long term car nut
    Feb 2006
    sunny florida
    stupid EPA
    it makes you go to 4th instead of second in normal driving.
    Real PITA, and been on LOTS of six speed cars. Trying for fuel economy.
    All the mod does is give you normal trans operation
    Steve
    06 300C SRT8
    DannyC's Avatar
    DannyC is offline Loudest SXT
    Nov 2006
    Lynchburg, VA
    Wait a minute. I don't understand how a manual transmission can stop you from putting it in any gear you want. Are you saying if you try to put it in second and all the conditions are met it goes into forth gear? That is retarded.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by stevesrt8 View Post
    Steve, I got that part
    Let me rephase that. HOW does it do it. I'd think that the stock system locks out the position and guides the shifter into forth instead of second. So now how does the aftermarket unit work??? Just bypasses the solenoid??. If that were the case, couldn't ya just unplug it, or does it have a return signal path or dedicated sensor to the transmission controller.
    bobbyj1 is offline LX Newbie
    Mar 2006
    I got mine from a Corvette vendor, they have been dealing with this issue for years. I believe the 6 speed trans is the same Tremec unit that is in the vettes. The elimnator bypasses the solenoid, the dash light will still come on but you will not be forced into fourth.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by bobbyj1 View Post
    Thnx, that's what I wanted to know. So based on that, I'll asume it's nothing more then a cap that plugs onto the wiring harness or in line with it with a resistor that bypasses the solenoid feed to keep the TCM happy with feedback.
