Results 1 to 10 of 10
    silk08's Avatar
    silk08 is offline LX Newbie
    Miami,FL
    wierd noise at my wheel well
    was driving as normal today when i went over a little pothole in the road nothing major nothing i havent went over before but then i heard like two tin cans bangin at my wheel well have any idea what this could have been ?? i went over a few more bumps and everything sounded normal i think its only when i go over them deeper holes it makes that noise
    Jimsmag06's Avatar
    Jimsmag06 is offline Is now an 07 SXT!
    Patterson,Ca
    I sometimes get the same thing on the bad potholes...I had the dealer look at my front swaybar links, and they said everything was tight.
    I also read in another post, that it was the front brake pads.....they said to get some of the Permatex anti squeak jel, and coat the back of the pads, and this should stop the noise. I haven`t done it yet, but it is on my list of to do`s.
    Jim
    07 MagSXT
    JBA Headers, R/T exhaust
    dchemi's Avatar
    dchemi is offline LX Enthusiast
    Rochester, NY
    I noticed a noise whenever I hit some bumps in the road coming from the front end. Not quite the tin can noise you described.
    I had the car in for some other work. When I picked it up they told me that they had noticed a noise from the front end while they were road testing it and that they replaced the tension struts. I have no idea what those are, but my noise going over bumps has stopped.
    The invoice says 4782613AC STRUT-SUSPENSION replaced.
    To me the sound was more of a rattle of something loose, more plastic sounding, but it might be worth the effort if you are still under warranty to have them check the tension struts.
    2005 Cool Vanilla Magnum RT (Mopar CAI)
    Phil056 is offline Madison & Morgan's Dad
    Smithtown, Long Island
    You might want to also check out if your tie-rod end is shot on that side. That's what happened to mine and every time I went over bumbs in the road, it made a metal-on-metal type noise. - Good luck.
    '05 Magnum SXT - Inferno Red
    Protection, Performance, Leather Pkgs.
    Boston Acoustics Pkg w/ Sirius
    bookeem's Avatar
    bookeem is online now All Black Everything!!!
    north jersey
    Quote Originally Posted by Jimsmag06 View Post
    thats what fixed it for me, except i used th crc brake quiet..same stuff different manf.
    and thi swas after the dealership replaced my rack and pinion, nope that wasnt he cause of the noise, then they replaced both yension struts, nope that wasnt the noise, untill i figured out, by reading other post on here, i think its the brake pads and sure enough they were the noise makers..
    i then applied the crc brake quiet to the front pads, gave them 10 minutes to dry , put hte pads back in, all has been well ever since, other than a damn brake squeel i never had untill i messed with the pads..now i cant get rid of the squeel, untill i get new pads and rotors, come spring time, lol
    Thank You Haz
    Dispdan311's Avatar
    Dispdan311 is offline LX Padiwan
    Jun 2007
    Connecticut
    I had a similar noise but it was a plastic creeking type noise.
    Do you have the plastic hubcaps?
    The reason why I am asking is because I heard this similar noise and it was just the hubcaps creeking as the wheels turned.
    Midnight Blue Charger SE
    K&N Cold Air Intake
    Honeycomb Grille w/Charger Grille Emblem
    Old School rear Charger Emblem
    Custom Dual Magnaflow Exhaust
    Debadged
    silk08's Avatar
    Miami,FL
    nope ive got the SXT wheels odd enough the noise stopped on its own i have no idea how this happend but it did o well im not complaining tho lol i was woundering if it had somethign to do with water the last week its been pouring by me and thats when it happend it stopped raining and the noise is gone .... weird
    Jan 2006
    Flemington, NJ
    Just a thought, maybe too obvious -- but are you certain the jack/spare tire assembly is tightly secured? May have loosened up over time?
    2005 Brilliant Black Magnum SXT
    ___________________________________________
    ~~~O' ye delicious smoked swinery~~
    Ruff n Tuff RT's Avatar
    Ruff n Tuff RT is offline THE PAVEMENT IS MY CANVAS
    HARBOR AREA
    i think this is normal
    i used to hear it alot
    and i also heard alot of people say they hear it too
    2006 CHARGER RT / ROAD & TRACK
    welshy411 is offline LX Newbie
    Jun 2008
    I had a rattle, clunk noise and my mechanic found that the pins for the caliper were worn and allowing the caliper to move around. Once he replaced them no more noise, and it cost $70.
