Results 1 to 15 of 29
    Big RobsR/T's Avatar
    Big RobsR/T is offline Biggest guy on the Forum
    Apr 2006
    Houston, TX
    Uhh ohhh...tick...tick...tick
    So I am driving home from Louisiana, normal driving nothing too hard except to pass some semis. I get back to Houston and get out of the car and hear tick tick tick tick. I get in and push the gas and it speeds up with the engine. I think it might be a lifter What should I do? I dont know if its under warranty because its at 49,000 miles and I think I bought an extended warranty but im not sure. Do the 2006 have the 70,000 powertrain warranty? Crap this is not a good thing to come home to after being offshore.
    2009 Stone White Challenger R/T 6-Speed
    JLT Carbon Fiber Intake||180 Jet Tstat||85mm ported throttle body||Predator||Petty's Garage Strut Brace
    SRT hood scoop inserts||Billet Tech Hood Emblem and Door Sill Plates
    tommygun's Avatar
    tommygun is offline LX Newbie
    Nov 2005
    kan$a$ city
    ive had a small tick since i bought the car. ive put 20k miles on it, no problems
    magwag's Avatar
    magwag is offline LX Padiwan
    Dec 2006
    Braidwood, IL
    mine ticks too.
    Apr 2006
    Houston, TX
    This isnt a little tick. I can hear it over everything else. I was next to a wall and it was really loud. Kind of has me worried, think I might take it to the dealer today.
    Jimsmag06's Avatar
    Jimsmag06 is offline Is now an 07 SXT!
    Patterson,Ca
    I would take it in right away.
    If you have the 3.5, check to see if the recall work was performed....sand in the main bearing i think?
    MooNDoGGie's Avatar
    MooNDoGGie is offline Absent From Malaise
    Cambridge, Ontario
    Quote Originally Posted by Jimsmag06 View Post
    I never received any notice of a recall for sand in the main bearing. Is this just recent?
    ____°º©Mo0NDoGGie©º°
    PERFORMANCE MODs: kw coilovers,zoomers exhaust,jba shortie headers,diablo predator,hammer h.o.CAI,power slot rotors,hawk pads
    COSMETIC MODS: 20" zinik's,msrt8 front fascia,colour matched fog light bezels & rear wing,shaved front badge,6000k HID headlights & foglights,shaved & debadged,tinted FOG tail lights
    INTERIOR MODS: nav radio,msrt8 kicker sub-woofer,T-handle shifter knob & leather boot,BT aluminum dash knobs
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    My buddy's daytona does the same thing.....always has. He's taken it to the dealer twice and they say nothings wrong. At least you should let them listen to it.
    BTW, mine ticks too......I think it's the FRI cam, 6.1 lifters, and longtubes!
    boggart's Avatar
    Pittsburg, KS
    2006 had the 3/36 powertrain warranty, sorry
    36 chambers's Avatar
    36 chambers is offline Banned
    ON A HOLLYWOOD SET NEAR U!!!!
    Need Some Money? Sell Me That Air Hammer Lol!!!!!
    high888's Avatar
    high888 is offline LX Padiwan
    Nov 2005
    Tampa, FL
    Quote Originally Posted by RPutney300 View Post
    Do you have the 3.5L? Here is my said tale. I developed a louder than normal ticking coming from the left side. Not your typical lifter tick. Louder. Annoying. So, the dealer started by changing out all of the lifters
    on the left bank of the engine. All 12 of them 'cause it was to hard to isolate which one was making the noise. But, no change. After calling around to some of the DCX regional big shots, one said this has happened before. So they changed out the left side rocker arm shaft. That was it.
    No noise. This was last October, with 24,000 miles on the car. Since then, my service advisor has seen a couple more come in. Same thing.
    If you need more info off of my customer sheet I can give it to you. The noise was coming from underneath the left valve cover.
    my wagon's Avatar
    my wagon is offline LX Padiwan
    Feb 2007
    somewhere
    my friend had the same ticking noise and she finally took it to the dealer , they said the lifters were bad and they replaced them
    Jimsmag06's Avatar
    Patterson,Ca
    Quote Originally Posted by MooNDoGGie View Post
    Hey Moon,
    I`ll look around for it...Was a pretty hot topic for a while.
    Apr 2006
    Houston, TX
    Well I took it to get the oil changed and now it sounds normal again. I did go about 4500 miles but it was on mobil 1 synthetic so I thought it would be fine. Apparently not, guess I wont be doing that again. Must have been making noise due to the oil and the temperature of driving at 80mph for 400 miles? Im not sure. Guess if it comes back I will be taking it to the dealer.
    Apr 2006
    Houston, TX
    Quote Originally Posted by 36 chambers View Post
    haha! Im good on the money front, I could probably go trade her in for a hemi now, but I think im just going to wait for the challenger to come out and see what happens. I havent even got the airhammer H.O. yet! I will take pictures when I do.
    Jimsmag06's Avatar
    Patterson,Ca
    Hey, Moondoggie....
    Here it is:TSB 06025 Check #2 crankshaft bearing for debris.
    I think a few people actually had their engines replaced...Fnky, You listening...You know more about it than me.
