I have a code 10016 on our 05 paciffica with the 3.5,it will not go over 3000 rpm at all.it has 47k on it,I am showing that code to be cam/crank sensor,has any one had a problem,and where is it located on the engine.
05 Inferno red sxt,01 red svt lightning 12.42@113.,95 corolla le,72 cutlass "s",06 chev express 2500
Is there a mechanic out there
Blinker Mod, Auto Headlight Mod,91 Pred Tune
Fog light Mod, Shaved and De badged,Silencer Delete,Hood Struts,Strut cover,Modified Exhaust Flo-king muffler Dual out with Resonators Deleted.
Cam/Crank sensors are an easy, and pretty cheap fix. They are a common failure on that engine:
Cam Sensor
To Remove:
1. Disconnect negative battery cable.
2. Remove air cleaner box.
3. Disconnect electrical connections to the camshaft sensor.
4. Remove the mounting bolts.
5. Remove camshaft sensor.
To Install:
1. Install camshaft sensor.
2. Install mounting bolts.
3. Install camshaft sensor electrical connection.
4. Install air cleaner box.
5. Connect negative battery cable.
Crank Sensor
The crankshaft sensor is located on the drivers side of the vehicle, above the differential housing. The bottom of the sensor sits above the drive plate.
To Remove:
1. Disconnect battery cables.
2. Remove the battery
3. Disconnect electrical connections to the crankshaft sensor.
4. Remove the mounting screw.
5. Remove crankshaft sensor.
To Install:
1. Install crankshaft sensor and push down until contact is made with transmission case. While holding the sensor in position, install and tighten the retaining bolt to 105 in. lbs..
2. Install crankhaft sensor electrical connection.
3. Install air battery.
4. Connect battery cables.
Hope this helps!
You don't have to burn books to destroy a culture, just get people to stop reading them.
Good Job on this
