Originally Posted by
Magnum375 Jr.
Ok so not to disapoint, but no pictures, we were pressed for time, so we didnt take any. But the stock manifolds at first looked impossible to get to. My dad's friend who is a mechanic, agreed to help me out, so we used his lift. Man, to start off, it's not as tight as i thought it would be, but its still tight. You have to remove the airbox and airtube, and unhooked the 02 sensors. We reached most of the bolts for the heat shields from up top, but had to use a few extensions for the bottom. So after we got all the heat shields off, we decided to do one side and then the other. We did the passanger side first. It was fairly simple, and the stock gaskets actually line themselves up. So after we got the passanger side on we took a short break to look over the parts. WTF...i just realized they put all the wrong sizes on their parts, all their nuts and bolts are 14 MM not 13MM. But luckily my mechanic knows his stuff, and can tell the size just by the looks of it. So we started removing the drivers side and realized, maybe its a good idea to unplug the battery. The stock manifold fell and hit the starter and sparked. So after we did that, that side went on fairly quick. So after we plugged in all the sensors, connected the pipes back up, and put the airbox back in, we put it down on the ground and started her up. Hey, its a sleeper....i couldnt hear a difference. So i had my dad rev it up, and there is a little difference, when its coming back down the rpm range, it gets a deep burble, like it is trying to come to life but is so hampered by the stock exhaust its useless. It also whooooshes more when i hammer it, from the air exiting the exhaust. So I took it out and man, what a difference. The low end rpm range is great. I can patch out now with the ESP off. The laggyness off the line is pretty much gone. But the computer is still adapting, because now my 1 to 2 shift is sloppy, I should probably pull fuse 11. But sorry for not having pictures, and this is a must do mod for any of the V6's looking for being the fastest.
Awesome, same experiavce hear, but I used their supplied gaskets
07 3.5L Charger K&N CAI, Magnaflow Cat back, JBA shorty's, DiabloSport 93 tune sold, 2010 Challenger R/T 5 speed. 180 degree Thermostat with fan settings lowered, CC, ceramic brake pads, slotted rotors, red and black caliper paint, Challenger label for calipers, Corsa Cat back, functional hood ducts, and hood struts, 93 custome DiabloSport tune, Mopar drop in filter, JBA Shorty's, Wideband O2, anti-sway bars front and rear, end links, and strut brace.
