Results 1 to 11 of 11
Thread: help please
    silk08's Avatar
    silk08 is offline LX Newbie
    Miami,FL
    help please
    how do you replace the bulb in your fog lights ???
    bipto's Avatar
    New Hampshire
    Remove the belly pan under the motor (4 10mm bolts), then remove the front fascia pan directly forward of it (8 7mm bolts and four push pin connectors, IIRC) - this will allow access to the fog lamp housings. Becareful when re-install the front fascia pan that you route the radiator drain hose through the hole cut for it...
    The Iron Mistress Galleries
    R.I.P. Dave...
    TWIST3D BLACK MAG's Avatar
    TWIST3D BLACK MAG is offline GEORGIA LX CLUB
    Columbus, Georgia
    bipto is the Man !!!!!
    Custom Signature by Hazman
    Georgia LX Club:
    His 'n' Hearse is offline LX Padiwan
    SE MI
    Quote Originally Posted by bipto View Post
    Or turn the wheels in the direction opposite of the bulb you want to replace, pull out 3 or 4 plastic rivets at the front of the fender well and reach in and change the bulb. It's a little tricky 'cause ya can only get one hand in there, but doable.
    His 'n' Hearse
    You know that Social Security stuff they take
    out of your paycheck? They're givin' it to me!
    cadzilla74's Avatar
    cadzilla74 is offline Does this smell like chloroform to you?
    Jun 2005
    FTW TX
    Get a bag of replacement rivets to start with. Turn wheel to lock. Pull out existing 4 plastic rivets and peel back inner fender well....stick your hand down there and twist to unlock/unscrew bulb holder....gently ease the holder and bulb towrads you, replace bulb (try not to get greasy fingerprints on it) and reverse the action. The replacement rivets push right in (try to get the Christmas Tree type ones, they hold real good.)
    TORREDAYTONA is offline Banned
    good job jack !!!
    bipto's Avatar
    New Hampshire
    Quote Originally Posted by cadzilla74 View Post
    The plastic 'rivets' or push-pin fasteners are reusable. I've had the ones in my wife's R/T in & out probably a dozen times over the last 2 years, and they're still tight...
    And goin' in from the side is cool - it'll save ya some jacking / ramping time, but I found that it was tricky getting the new ones in without thumb-printing the bulbs...
    R.I.P. Dave...
    cadzilla74's Avatar
    Jun 2005
    FTW TX
    Maybe I just went too "gorilla" on my rivets with a pair of Kleins but I definitely distorted the heads on a couple pulling them out. The sack of 12 replacements was only a couple of dollars...
    SE MI
    . . . I found that it was tricky getting the new ones in without thumb-printing the bulbs...
    Try using nitrile or powder-free latex gloves (ask your family Dr. for a pr.), or even the vinyl ones food handlers use. I think most fabric gloves would be too thick and clumsy. I bought some very thin cotton ones used in clean room assembly from a lab supply house. Great for this kind of work.
    His 'n' Hearse
    silk08's Avatar
    Miami,FL
    i always knew i could depend on the forum for anything thanks guys!
    soccerbachelor's Avatar
    soccerbachelor is offline chargermark!
    Aug 2007
    Chesapeake, VA
    I don't know if it is different for a Charger to a maggie but I didn't turn the wheel, and got both hands in there. 2 10mm bolts and 3-4 plastic rivets, took me 10 minutes, mostly to see what I was going to do. I just yanked the plastic splash guard down and everything was accessible. Maybe it changed with years??
    06 Charger SXT Midnight Blue, 18" R/T rims, custom pinstripe, 20% tint, 6 disc in dash w/ MP3, fog lights, locking gas cap, color match SRT-8 spoiler, 3 script emblems, visor disguiors, 8000K HID conversion, K&N CAI, Exhaust Depot duals, Predator, chrome mesh grille, tomtom one GPS, custom center console. Pre-Diablo: 194.4 RWHP 220 ft/lbs TQ. Wife's ride 04 Grand Cherokee 4X4 special edition.
