to be in place of the jet module.....
reason for asking this, is the jet does its work by telling the computer via the IAT sensor, that cooler air is comming in, and the computer adjusts from the fooling of it....
however the air comming in always hotter than what the jet chip reports. hence the more fuel, and advance of spark...
the Cryo2 system by DEI actually cools the air, comming in by passing the air past a bulb or honeycomb (similar to a catalytic converter), and the IAT sensor will read the cooler air and adjust the same way the jet module does...
however heres the advantage, the air comming in, is actually cooler and more oxygen dense, hence better combustion and more power.
just a thought for yas... systems can be found on ebay for around the jet module price, and if you look around for dealers you can find deals...![]()
, things that have been proven to work...
i've seen pistons go through hoods from early spraying, but when done right can be safe, but only for track use, most places its illegal outside of the track.
