Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    thelastgoodbrother is online now Code name: Colossus
    May 2006
    Mount Vernon, NY
    Engine swap...what's needed
    I was looking at another thread that referred to us 2.7 owners swapping our engines to a 3.5. I am interested in this prospect...since I know that I am upside down on my car and the fact that I have dumped major bread in this car already.
    What is needed for a correct swap of this magnitude? My car was a fleet car, so I have ESP and a power seat. Other than that I don't know what the differences are between me and a stock SE. I see on ebay right now a 3.5L for 2100.00. I haven't shopped around yet so I am quite sure I can get one for less. Will I need a new ecu? What about the transmission, which is a 4spd? Thanks...this website is the best
    BONE STOCK
    PhatPhat is offline Banned
    Feb 2007
    LA 818
    i want to know the same thing, show the 2.7 some luv mang.
    TMag's Avatar
    TMag is online now Mopar or Nocar
    Texas
    3.5L comes with a 5spd auto, so you would have to upgrade to that also. You would also need the pcm/tcm for both. Probably wiring harness to match. Do you have a Pick-a-Part, I would look into those to find whole set-up.
    Mods- De-molded/Hood to Fender Stripe/Mopar Performance Intake/SRT8 Rear Deck Spoiler. Mods on Deck- Flowmaster Super 10's, Blastin Bob's GPSSR250 Pipes, Diablo InTune, MSRT Rims 20x9/Vred's 270/40/20 fronts, 315/35/20 rears.
    DannyC's Avatar
    DannyC is offline Loudest SXT
    Nov 2006
    Lynchburg, VA
    I'd love to put a 5spd tranny in my SXT. That would solve the B&G flash and give me better excelleration with the extra gear.
    Any info on either one of these swaps?
    MooNDoGGie's Avatar
    MooNDoGGie is offline Absent From Malaise
    Cambridge, Ontario
    You don't need a 5sp tranny. I have a 3.5l with a 4sp transmission. I'm not sure the suspension is adequate though. You might need to upgrade that. Not sure though.
    ____°şİMo0NDoGGieİş°
    PERFORMANCE MODs: kw coilovers,zoomers exhaust,jba shortie headers,diablo predator,hammer h.o.CAI,power slot rotors,hawk pads
    COSMETIC MODS: 20" zinik's,msrt8 front fascia,colour matched fog light bezels & rear wing,shaved front badge,6000k HID headlights & foglights,shaved & debadged,tinted FOG tail lights
    INTERIOR MODS: nav radio,msrt8 kicker sub-woofer,T-handle shifter knob & leather boot,BT aluminum dash knobs
    TMag's Avatar
    Texas
    Quote Originally Posted by DannyC View Post
    You can swap your 4spd for a 5spd(Nag1), you would need to get a new tcm for it I believe.
    May 2006
    Mount Vernon, NY
    So is your 4spd different than a stock SE's? If not, then I wouldn't have to do the tranny swap.
    I have srt springs and rt sways...
    BONE STOCK
    TMag's Avatar
    Texas
    The 4spd is either a fleet car option only or Dodge changed it, 4spd is not available thru Dodge website, only the 5spd is for the 3.5L.
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    I would look at:
    www.dodgeintrepid.net
    Do some searches... they have quite a few members that have swapped 3.2L and 3.5L engines into their 2.7L rides.
    The transmission bolt patterns are the same, so there is no NEED to swap transmissions. the 4-speed will operate with the 3.5 just fine. If you don't like the tranny... good luck on the swap, i think it will be MUCH MORE difficult than swapping the engine.
    The 2.7L ECM *SHOULD* be able to run the 3.5, without any real "modifications". The fuel tables (and bigger injector sizes on the 3.5) have enough room to put more fuel into the engine so it won't damage anything... a B&G flash would sort out anything that may cause issues... (that will be a custom flash though, so it may get pricey)
    Manifold tuning valves and such are all "configurable" and, in the end, unnecessary. you just hook up the connections you have available on the 3.5 (I think someone said the 3.5 had 2 tuning valves, and the 2.7 had 1... just hook up the 2.7's to the 3.5's most appropriate one, and tie the other either open or closed.. whatever fits your driving style best). DON'T LET A TUNING VALVE DISSUADE YOU FROM DOING THE SWAP. They are usually there to "pad the numbers"... and the 3.5 will be a HUGE bump in performance, even without them operating fully.
    This all sounds a LOT easier than it is. changes of this scale will run you into roadblocks and dead ends... but it IS do-able... and it will be a VERY valuable resource for other LX'ers in the field, if you choose to chase this path.
    PS:
    The 4.0L Pacifica and Nitro engines are the same "block", with more displacement as the 3.5L blocks. Maybe check into those... fnky had some advice about the differences a short while back, search for that info if you want to go "all the way".
    Cdn_Magnum's Avatar
    Cdn_Magnum is offline LX Guru
    Jun 2005
    KW, Ontario , Canada
    Quote Originally Posted by TMag View Post
    Thats not a true statement. All the '05 and early '06's had a 4 speed transmission in them (3.5's). The mid '06 switched to the 5 speed.
    Russ
    - Falken 20" Explict Black rim,Falken 255 45 20 tires,8"LCD monitor headrests,12" LCD monitor in custom tri fold in back,custom made CIA,Infinity engine cover w/custom paint,custom painted centre bezel & console,custom lit cup holders, LED interior lighting & grill lites,HID's,300w sub amp w/custom enclosures,custom hand-made mesh grill
    TMag's Avatar
    Texas
    Quote Originally Posted by Cdn_Magnum View Post
    Or Dodge changed it, which they obviously did.
    CANDYAPPLE's Avatar
    CANDYAPPLE is offline Jammy Beggar
    Mississauga 2005 Magnum SXT
    It's interesting when Russ and I and a few other SXT's (V-6's) get together to pick out the subtle differences that were made on an ongoing basis. My early '05 (Build date Aug 04- now with 9000 miles on it) has black headlights, 4 speed, black outside mirrors, fog lights N/A etc. These all changed over the model year and into the '06 line.
    Cheers CANDYAPPLE
    LX #1.....2011 Toxic Orange Charger R/T R&T (license plate "BUK8LIST") Aria CAI. Window tint.
    LX #2.....CANDYAPPLE...2005 Magnum SXT, Predator, JBA, AirHammer HO, Borla, Eibach Pro-Kit, SRT sways, Power Slots, 20" Cragars/Toyos, Daytona Spoiler, AAR Stripes, R/T rear bumper cover.
    ASU_Magnum's Avatar
    ASU_Magnum is offline I'll be back...someday
    Nov 2005
    Phoenix
    with how touchy these cars are with their computers being messed with, I would be amazed if it was a straight, no problem swap.
    2005 Magnum SXT Bright Silver - SOLD
    2006 Yamaha R6 Raven -STOLEN
    Quote Originally Posted by Zmagnum
    You are famous. You have the fat woman sittin' crack findin' Magnum
    lafrad's Avatar
    Feb 2004
    Muskego, WI
    Quote Originally Posted by ASU_Magnum View Post
    Don't mess with the computer.
    The stock computer can *almost* run my highly altered engine.. just needs help idling due to low vacuum from the cam. a stock cam, or even just "mild", would run, without complaint, on the stock computer.
    A 3.5L engine with stock cams will have a similar vacuum to the stock 2.7L (and therefore, idle fine, startup fine, and learn the adaptive memory fine). The question will be "what sensors are needed", and the Dodge Intrepid guide answers that.
    i would assume, if anything, the new Engine computers in the LX's will be MORE forgiving than the old LH Engine computers.
    May 2006
    Mount Vernon, NY
    Not worth the trouble...
    I guess I will ride slow until I decide to step it up.
    BONE STOCK
