Results 1 to 13 of 13
Thread: Engine Noise
    Bigdirtyd's Avatar
    Bigdirtyd is offline Dirt Ma Girt
    Nov 2006
    Indiana
    Engine Noise
    I started to notice a weird noise when my car is in drive and at an idle with break pressed. It goes away once the break is released and start moving.
    I swear it sounds like a coffee machine making coffee in the morning.
    Anybody know what this is???
    Let me know. PM would be preferred.
    ZMagnum's Avatar
    Tucson, AZ
    Is it a clicking or racheting sound? That's the transmission. My Magnum as well as my 2000 Durango makes the same noise. Totally normal.
    Bigdirtyd's Avatar
    Nov 2006
    Indiana
    it sounds like a coffee maker.ha. its like a bubbling sound to me. maybe a little ratcheting mix. Just seems louder. maybe i never noticed before. Its too hard for me to describe i guess.
    ZMagnum's Avatar
    Tucson, AZ
    Well I hear it every time I put it in drive with the windows down. Do you have the 4 speed transmission or the 5 speed auto-stick?
    fnkychkn's Avatar
    greasy cardboard box
    possible candidate for TSB 24-007-05.
    Bigdirtyd's Avatar
    Nov 2006
    Indiana
    I hear it with the windows up and no radio/ac/heat going. It comes from behind the steering wheel. Its the 4 speed. And only when In Drive but stopped with the break pressed down.
    Bigdirtyd's Avatar
    Nov 2006
    Indiana
    thanks funky chicken. cept its still more of the bubbling weird sound then knocking noise.
    ZMagnum's Avatar
    Tucson, AZ
    You got me on this one.
    My brake pedal used to make a noise when I pressed it but it was a spring sound. It just needed some grease.
    This is probably something your dealership's Techs should hear.
    fnkychkn's Avatar
    Quote Originally Posted by Bigdirtyd View Post
    low coolant gurgling through heater core?
    Bigdirtyd's Avatar
    Nov 2006
    Indiana
    ok. my break does that too. the spring noise. drives me crazy. just grease it? I guess ill have to take it in to be checked.
    fnkychkn's Avatar
    If you encounter a noise during brake pedal application, apply lithium grease to the spring located at the brake pedal pivot point. The grease should be applied to all surfaces of the spring and at each of the hard contact points to the pedal assembly. Exercise the pedal to insure that the noise is suppressed with the grease applied. Please take caution to not apply an excessive amount of grease. During the summer months the grease can soften and drip off the assembly and onto the carpet.
    redsledrt's Avatar
    redsledrt is offline Blink and I'm RT Gone.
    May 2005
    Northern Virginia
    I've had 3 A/C compressors replaced by the dealer although the problem was misdiagnosed for at least two of the three. I had an intermittent noise (groan/grinding/rattling) that would only occur when the AC compressor was engaged. Sometimes to get the engine to produce the noise I'd have to apply the brake hard. I thought the noise was coming from the passenger side but the dealer tech would just place another order for an A/C compressor (drivers side). I didn't delve ito it too much myself at first because my dealer provides a loaner car and my Magnums under warrenty, but after many weeks of this I took my stethoscope/tube with me to the dealer and convinced them that the noise was coming from the alternator. Possibly a bearing going bad we thought. When they were about to install my new alternator they discovered the source of my noise. The lower alternator bracket was loose and unattached at the exhaust manifold. I've got Gibson headers and there is no place to attach this bracket. My installer just left that end unattached and the bracket worked loose at the alternator and vibrated under certain conditions, say when the engine was under A/C load or recovering from a hard stop. Strange but true. The bracket is item '1' in the drawing.
    EDIT: Oops just noticed this thread and TSB is for the V6 SXT.
    05 Magnum R/T, FRI Tomahawk Cam and Street Heads milled, Mopar Headers, Dynatech PowerCAT, Borla 112, AirHammer AVS-2 CAI, ProTorque 2800, Diablo Predator, CMR by Steve @ RDP, Mopar TCM, NoESP Mod, 180 TStat, FT31 20x8.5 Forged wheels, Toyo Proxes S/T 255/45R20, M/T ET Street 275/40R17 DR, KW-V1 and Hotchkis Sways, LSD Lambo doors, Katzkin SRT Seats, E&G Classic Grill, RamAir Hood, HIR bulbs, 'ParkSense' back-up sensors
    Bigdirtyd's Avatar
    Nov 2006
    Indiana
    my friends dad said it could be Low Coolant Level or possibly my Break Booster going bad. He owns his own Auto shop so I hope when I take it in and tell them this they can figure it out pretty quick.
