Results 1 to 7 of 7
    Christopher's Avatar
    Christopher is offline LX Padiwan
    BADEN Ontario Canada
    Black gunk in my throttle body .
    Was cleaning my K&N oem air filter when I noticed their was some black deposit in the throttle body flap , I opened the flap to find more of this black gunk in the throttle body , I want to know if anyone may know what this is from is this oil from my I&N and if this is can I open that big air passage on top of my engine and clean it out ?
    ZMagnum's Avatar
    Tucson, AZ
    Quote Originally Posted by Christopher View Post
    More likely oil from your crank case vent hose. I'm not sure about cleaning it out but I know it's a pain to remove the plastic intake manifold if that's what you mean. You can use Mopar combustion chamber cleaner to clean it all out. Check out this thread, especially Fnkychkn's instructions.
    fnkychkn's Avatar
    greasy cardboard box
    if you just want to clean the throttle body, use a clean rag and wipe it off.
    Leadfootluke's Avatar
    Leadfootluke is online now LX Guru
    Grand Rapids area
    I use Seafoam Deepcreep, and The Original Seafoam liquid stuff. Warm engine, shut off, open blades wide, spray and soak, wipe off, and start engine. Simple aerisol can.
    But yes, just wipe it off, carbon build up.
    HammerStyleIntakeBilletTechBlastinBobTommyZDesign
    black MAGic's Avatar
    black MAGic is offline LX Padiwan
    NC
    Black build up
    I had an issue where my Magnum would "bog" down during acceleration when the engine was cold. It continually got worse until I had to take it in for service. The service guy at the dealer said there was a large amount of carbon build up in the throttle body. He said this carbon build up was causing the hesitation. He also said it was a common issue. Just FYI.
    MooNDoGGie's Avatar
    MooNDoGGie is offline Absent From Malaise
    Cambridge, Ontario
    The 3.5 is a high output engine. If you don't drive it hard it will carbon up. Don't be afraid to get the RPM's up in the 4000 or 5000 range regularly. This alone will make your engine run much better.
    ____°şİMo0NDoGGieİş°
    PERFORMANCE MODs: kw coilovers,zoomers exhaust,jba shortie headers,diablo predator,hammer h.o.CAI,power slot rotors,hawk pads
    COSMETIC MODS: 20" zinik's,msrt8 front fascia,colour matched fog light bezels & rear wing,shaved front badge,6000k HID headlights & foglights,shaved & debadged,tinted FOG tail lights
    INTERIOR MODS: nav radio,msrt8 kicker sub-woofer,T-handle shifter knob & leather boot,BT aluminum dash knobs
    Thanks , I Put 500+km On My Car Each Week , Gas At $105-110 Per L
    I Try To Keep The Auot Stickin To A Min .
    Good Tip , Thanks ..
