Results 1 to 15 of 16
    eds9c1 is offline EDS9C1
    Hatboro Pa
    3.5 thermostat replacement......how and where?
    Anybody here ever replace the stat in their 3.5 engine?
    I think i found the housing.......but was wondering how involved it was to chang out.
    Ed
    2007 Charger 3.5 HO
    2007 Charger 2.7
    1995 Caprice 9C1 police package
    fnkychkn's Avatar
    greasy cardboard box
    from fsm:
    3.5L ENGINE
    1.Disconnect negative cable.
    WARNING: Do not remove pressure cap with the system hot and under pressure because serious burns from coolant can occur.
    2.Drain cooling system.
    3.Raise vehicle on hoist.
    4.Disconnect electrical connectors from engine oil and power steering pressure switches.
    5.Disconnect radiator and heater hoses from thermostat housing.
    6.Remove thermostat housing bolts.
    7.Remove housing, thermostat, and gasket.
    NOTE: The OEM thermostat is staked in place at the factory. To ensure proper seating of replacement thermostat, carefully remove the bulged metal from the thermostat housing using a suitable hand held grinder. It is not necessary to restake the replacement thermostat into the thermostat housing.
    t-stat housing bolt torque spec: 105 in/lb.
    RodneyUSAF is offline KISS Keep It Simple Stupid
    Oxford, United Kingdom
    How about the 2.7? Does anybody have a diagram? I have to replace mine whenever it gets here. (overseas so it takes awhile) It looks like it will be tricky to get to. The dealer told me that the 2.7s were bad about air pockets and have to be bled whenever the coolant is drained. That must be why they put that big bleeder valve on the hose!
    fnkychkn's Avatar
    Quote Originally Posted by RodneyUSAF View Post
    pm sent
    ChargLex's Avatar
    ChargLex is offline Powered by the 3.5L V6 and proud of it
    21 miles from the LX factory
    Don't do this if all you want is a 180 degree thermostat, as there is an extremely good chance you already have one.
    I bought a Jet Chip and their website says it "requires" a 180 degree thermostat... meanwhile my '06 Charger SXT already has one. There should be plenty of old threads with info on how to find out if you already have one.
    Regards,
    ChargLex (Lex at Chargerforums)
    2006 Charger SXT 3.5 NAG1 5spd autostick · DiabloSport Predator 93 Tune · Ceramic Coated JBA Shortie Headers · AirAid CAI · Custom Magnaflow Dual Exhaust · Modified DC Sports strut bar · MyGig RER NAV with Lockpick Adapter (PAC Line-In Adapter FOR SALE) · Pinnacle ceramic 35% tint
    Na, I am having cooling issues. Not worried about 10 degrees one bit. The temp will stay at 1/4 for the first ten minutes, then quickly rise to a little over half. I haven't driven very far since the problem began, so I don't know if it will overheat or not. I just know it's not right. Plus I am getting code 0126.
    fnkychkn's Avatar
    P0126?????? not familiar with that one.
    DannyC's Avatar
    DannyC is offline Loudest SXT
    Nov 2006
    Lynchburg, VA
    DTC P0126 Insufficient ECT for Stable Operation
    fnkychkn's Avatar
    Quote Originally Posted by DannyC View Post
    thanks DannyC. haven't come across that one on any chrysler vehicles yet.
    COLORADOMAGNUM's Avatar
    COLORADOMAGNUM is offline I'm not speeding......I'm qualifying
    Lakewood, CO
    Quote Originally Posted by ChargLex View Post
    If you have the "severe duty enging cooling" option, you already have the 180* t-stat. Your dealer can run your VIN # and let you know (it's not on the window sticker).
    I found out the hard way. I bought a 180* t-stat, took everything apart, then found out I already had a 180* in my car.
    2005 Magnum SXT AWD - Inferno Red
    Mods: Diablo Predator, JBA headers, Zoomers single exhaust, K & N Aircharger, KW coilovers (variant 2's), 402 Motoring tinted tails, lots of Billet Technology stuff, real walnut dash kit, MOPAR on-dash nav, NC-SXT original honeycomb grille, Jina's Embroidery custom headrests.
    Hatboro Pa
    Thanks fellas!!
    I will check the Vin with the dealer tomorrow.
    2007 Charger 3.5 HO
    2007 Charger 2.7
    AvengerRT's Avatar
    AvengerRT is offline Pimpin' ain't e-z but its necessary...
    Shelby Township, MI
    What kind of temp are you guys running on the 3.5? Right now mine sits just a tad less than middle of the gauge, occasionally reaching the middle but never above. Its been cold out lately, the highest being 40 some degrees. I don't have the evic so I can only go by the guage, but am I running too hot? I checked my codes today and I don't have any set, so I suppose thats good, but I just wondered about the temp.
    Thanks in advance!
    ChargLex's Avatar
    My Charger SXT is at operating temp at the middle of the gauge...
    Regards,
    ZMagnum's Avatar
    Tucson, AZ
    Mine is the same. Middle to just left of middle once warmed up. Middle is 200 degrees BTW.
    Josuave's Avatar
    Josuave is offline LX Padiwan
    Toronto
    Just had the Stealership replace my water pump under warranty. It went on me, they suggested the thermostat stuck closed and caused the seal to go on the pump. They charged me $180CDN for the thermostat and replacement, also said I needed a coolant flush, so another $90 for that.
