Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 84
Like Tree12Likes
Thread: 3.5 High output owners... is the predator worth it?
  1. #31
    hskr is offline Banned
    Feb 2009
    Nebraska
    Quote Originally Posted by gunracer View Post
    Hey hair, are you running a true cai into the fender or are you running a short ram intake? Your torque number are the same as mine were when I pulled without the filter in the fender. My other pull was with my short ram. The torque curve peaked at 218.
    Yes, I have a fender pull "true" CAI. Have not tried it with out the tube into the fender. From past experience it's always been better to get the filter out of the engine bay, especially at low speeds or when stopped than to suck in the hot underhood air.
  2. #32
    DET-TANK's Avatar
    DET-TANK is offline From the D but in the NC
    Sep 2011
    WNC
    Running the 93 CAI Canned tune, I saw IMMEDIATE positive changes in how the 300c accelerated and drove in general. I then raised the shift points and the shift firmness with the preset levels available.
    I am VERY happy with my purchase. Paying $135 shipped from a member here was a bonus!
    2007 Brilliant Black Crystal Pearlcoat
    300C
    5.7L Hemi Registry #1646
    Diablo Sport PREDATOR 93 Octane CAI Tune/AFE Stage II/BT Oil Catch Can/
    Suitcase/Res delete/Flowmaster axle back/
    #4128 T-Stat/15% Tint/All LED Interior Light Swap/BT Interior-Under Hood Mods
  3. #33
    scott386's Avatar
    scott386 is offline LX Padiwan
    Jan 2009
    st.louis,mo
    Another question : Can i use the tuner on both my magnum and charger? Both have the 3.5.....
  4. #34
    H20burycharger's Avatar
    H20burycharger is offline NEMC Member
    Feb 2011
    Waterbury, Vermont
    Quote Originally Posted by scott386 View Post
    If I'm not mistake only one vin # or car at a time.
    The Waterbury Charger
    2009 SXT 3.5 H.O. 5% Rear tint and 15% Front tint, GT Style Vent Guards, Black R/T Style Spoiler,Daytona front lip, Daytona grill inserts, Daytona Rear Decal, 10,000k HIDs for fogs, Blackout Grill, Kenwood 800 Watt AMP with two 12's, L.E.D Interior Bulbs and license Plate, 2011 dodge emblem on the grill, Flowmaster 50 Series, K&N 63 Series AirCharger High-Flow Intake Kit, Powerstop drilled/slotted rotors, Diablosport Predator 93 octane and Mopar Stage 1 Springs.
    With More to Come!!!!
    http://www.cardomain.com/ride/385851...r-sxt-sedan-4d
  5. #35
    Feb 2009
    Nebraska
    You can, but you can only use it on one at a time. meaning if you have a Diablo tune in your charger, your Magnum will have to be set to stock first and vice versa.
  6. #36
    gunracer's Avatar
    gunracer is offline dsm n.o. member
    Oct 2009
    new orleans la
    True, but at idle our intake tubes sit right over the left header bank and it will be sucking up a lot of heat regardless of where you are pulling from.
    Quote Originally Posted by hskr View Post
    trufiber ram air hood, diablo sport tuner w/ 93 oct. gas on the 91 oct. tune, ported and polished lower intake manifold, ported and polished throttle body, magnaflow muffler, blastin bobs 10 db exhaust system with the 4" tips, big bully cia, big bully catch can, 160 degree stat, jet hot coated jba shorty headers, lowered and ridin on nitto 420's 255 45r20
    fastest time- 15.532@ 89.52
    "Speed never killed anyone. suddenly becoming stationary, now thats what kills you."
  7. #37
    torred 3.5's Avatar
    torred 3.5 is offline LX Padiwan
    Oct 2010
    METRO Detroit Area
    fender pull is still better overall, I still have to install, it's an ebay one. Funny thing is the ebay one is the cheapest, but it's the most authentic CAI.
    2008 Dodge// Charger SE Plus 3.5
    TORRED exterior, daytona matched spoiler, honeycomb grille insert, matte black grille, trunk blackout, chally style rallye stripes, visor disguisers, cobra radar detector, aac hod highs and lows bulbs, black side markers.. more mods will come soon(I hope) to do: chin spoiler, wheels to pd....
    Charger bought new, 10 minutes from Chrysler headquarters on December 30, 2008.
  8. #38
    Stumblin Steve's Avatar
    Stumblin Steve is offline LX Newbie
    Mar 2009
    Richmond, VA
    Quote Originally Posted by torred 3.5 View Post
    I would look into at least replacing the elbows because eBay intakes are so cheap it may mean some of the material is cheap and may collapse under the pressure, I've heard of that happening.
    Just your friendly neighborhood...Charger.
  9. #39
    Feb 2009
    Nebraska
    The problem isn't so much the intake tube sitting above the exhaust. Once air starts flowing the intake tube, being metal, cools off relatively quickly. The problem is the plastic intake manifold that gets heat soaked sitting right on top of the motor. When data logging at the track if I park to try and let the engine cool down, the intake manifold heat soaks and takes forever to cool off. Even after 1 hour of sitting with the hood up as soon as I start the motor the intake temp sensor is reading close to the same as the coolant temp, and took about half way down the track at WOT to even come close to getting to the outside air temp coming in through the CAI. Where as if I hot lap even with sitting still for a couple minutes, the intake temp stayed lower due to the cool air flowing in from the intake keeping the manifold cooler and intake air temps cooler, which is also how I ran my best pass at the track. It was the fourth run of back to back hot laps with only a couple minutes spent in the staging lanes each time.
  10. #40
    torred 3.5's Avatar
    Oct 2010
    METRO Detroit Area
    I'm actually kind of getting excited for the predator, i want to know what it feels like to get an extra 15 or so hp.
    I see a lot of people run 93 and 91 tunes, what's the best for a daily driver that does 100% city driving?
    and can i run a 91 tune with 89 octane and maybe aces IV added in that? Thanks for the help in advance.
  11. #41
    jonny's Avatar
    jonny is offline Mayhem
    Oct 2008
    Upstate NY
    I always just ran the 93 tune with 93 octane... I see the extra $2 per tank as inconsequential.
    Do the math, yourself. It isn't "free" like advertised (ACES), check your local gas prices differentials, and what you paid for the product WITH SHIPPING. It comes out to about $0.40 per gallon. Last I checked, the differential between mid grade and high test was $0.10 per gallon. (We only have 87, 89 and 93 in my area)
    10.6 tankfulls per quart of ACES, about $7 per tank extra for the additive, versus less than $2 (or $4 depending on location) for using the right octane to begin with. Someones math is a little... off.
    Your best bet to know if you can run reduced octane with a higher tune is to do what I did, and it's a simple test. Hook a laptop to your Predator, run the gas you expect to run (89 and ACES IV in your example) and datalog some good hard runs. See if you have knock. I would think it's also important to datalog right when you switch over, so the adaptives don't just pull timing and learn to keep it that way... not sure how long term it pulls timing, but I would imagine you could have reduced timing and not show on your Predator or logs.
    FWIW, driving normally you could probably run 87 and a 93 tune without knock... but step on it a bit and you'll have a boatload.
    Run what you want for fuel, just make an informed decision about it.
  12. #42
    gunracer's Avatar
    Oct 2009
    new orleans la
    I run the 91 tune with 93 octane gas. The 91 tune doesn't have as much timing as the 93 tune so on a hot day with a hot motor you knock sensors should stay a little quieter. But nothing beats a custom tune.
  13. #43
    gunracer's Avatar
    Oct 2009
    new orleans la
    Its not the intake manifold that matters temp wise its the turn just before the throttle body that hold the temp sensor. I had my intake tube jet hot coated to keep the heat out a little longer but like all metal, no matter what you do to it if its left in the heat long enough it will get soaked. Now, I have a dual ram air set up on my car. One is in the obvious place, my hood. It really starts cooling my intake at 45-50 mph. But my secondary and the one that works first is my lower ram air. Since im running a srt bumper I utilized the brake duct but before then when I got to the track I would remove the driver side fog light and attach the ram air tube there via a metal plate that I made and piece of 4"od tubing and some 4" flex hose through the factory hole and it starts cooling g at around 20. Now, I taped my hood off and used the lower only for a couple of passes and found that launching off the line with an intake temp of 110, by the time my car shifted into second(45mph) intake was 80, crossing the finish line it was 60. Outside air was 60.
  14. #44
    Feb 2009
    Nebraska
    Yes you can run the 91 tune on 89oct with the Aces IV, or the 83 tune on 91oct with the AcesIV. I've data logged both ways and you get minimal KR at WOT
  15. #45
    Feb 2009
    Nebraska
    I have the SRT style bumper as well, but don't go to any extra lengths to get a ram air effect with my fender pull CAI. I've also noticed that if I laucnhed with a intake temp any higher than 100 degrees my times suffered significantly. My best run of 9.85 1/8th mile came with about a 90 degree intake temp when launching and it had hit about 55 degrees by the end of the run. Outside airtemp was low 50s. And that was the end of those 4 consecutive hot laps. Letting the car sit to try and cool down resulting in 150+ degree intake temps upon launch and never getting below 70 degrees by the end of the run. Now obviously the air coming in was cooler than that as it takes a while for a heat soaked temp sensor to cool down. Maybe I should move the temp sensor closer to the hole in the fender where the tube goes through. Have the PCM bump the timing sooner.
    I also launch with foot on the brake and gas pedal all the way down, then just let off the brake. Gave me the most consistent 60' times and best ETs rather than trying any other way.
