Results 1 to 15 of 18
    DaILLestWun's Avatar
    DaILLestWun is online now DUDEBRO!!!
    Pembroke Pines, FL.
    3.5 Dyno results
    So I went to get the ride dyno'd. Great place!! I made almost 187 RWHP and 212 ft./lbs. of TQ. I'm really happy with the TQ numbers. This was with the stock intake and just my Exhaust Depot Exhaust. The scan is kinda crappy looking but you can kinda see the numbers below.
    World's first tuned V6 LX!!
    -Jimmy aka Jimbo
    mhigham's Avatar
    mhigham is offline LX Guru
    Feb 2007
    Michigan
    Maybe I can't see it well, but it looks to run pretty lean until like 5200. Something wrong with their equipment? If not, I would not run that lean at WOT.
    Mike
    06 Magnum R/T Midnight Blue
    Pembroke Pines, FL.
    Yeah it's running quite lean and then a little rich. weird....
    -Jimmy aka Jimbo
    NC-SXT's Avatar
    NC Coast
    Quote Originally Posted by mhigham View Post
    Mike
    I have a feeling its just the motor dynamics on these 3.5s. I am not sure but the chicken said somthing about the valves (4 valves per cyl) opening up more at around that point. These are higher reving motors then the 5.7s.
    WWW.DodgeMagnumGrille.com
    Kuldip's Avatar
    Kuldip is offline BCLX member 001
    burnaby, BC
    nice, thank for sharing, hey DaILLestWun i am gonna do mine this week, just for the hell of it, see what it really puts out.but how does the car puts out 180+ HP when the specs say 250+, can some educate me please.
    We must question the story logic of having an all-knowing all-powerful God, who creates faulty Humans, and then blames them for his own mistakes. – Gene Roddenberry
    Big RobsR/T's Avatar
    Big RobsR/T is offline Biggest guy on the Forum
    Apr 2006
    Houston, TX
    250 hp is at the crank on the motor. You lose power as it is transferred through the drivetrain to the wheels.
    2009 Stone White Challenger R/T 6-Speed
    JLT Carbon Fiber Intake||180 Jet Tstat||85mm ported throttle body||Predator||Petty's Garage Strut Brace
    SRT hood scoop inserts||Billet Tech Hood Emblem and Door Sill Plates
    Pembroke Pines, FL.
    Exactly. This is what dyno's are for. To see what kind of HP and TQ you are actually putting down to the ground.
    My HP #'s are about the average for our cars. The torque is actually pretty high. I think one guy had his TQ around the 170's or 180's which is pretty low. But usually people are around 200 when it comes to torque.
    I actually dyno'd first in the 190's HP and about 204 torque or something but it was on a cold engine. I wanted to see what I had with a hot engine.
    -Jimmy aka Jimbo
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    Some engines are able to safely run in Closed loop mode at WOT. The 3.5L engine may be one of those engines.
    mhigham's Avatar
    Feb 2007
    Michigan
    Quote Originally Posted by NC-SXT View Post
    Just seems awful lean to me. Thats not where the power is made and can be harmful to the engine running on the edge like that. One weak plug and its new engine time. Maybe its the way it runs, maybe they had a leak in their sampling equipment.
    If they are higher revving, then why stop at 5600? Most HEMI's dyno closer to 6,000, some over with any light mods.
    Mike
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    not too bad considering the mods....get you a CAI and some other goodies and you will be in business.
    Pembroke Pines, FL.
    Mike
    Speed limiter.... I hit 115 pretty damn quick
    -Jimmy aka Jimbo
    mhigham's Avatar
    Feb 2007
    Michigan
    Quote Originally Posted by DaILLestWun View Post
    Ah, gotcha. Chip time I guess, uh?
    Mike
    Pembroke Pines, FL.
    I'm getting the jetchip for now and see how that goes. Already time to dyno again..lol
    -Jimmy aka Jimbo
    pigpen's Avatar
    Minnesota
    Looking good My dyno for my SE was 165 with a exhuast, should be fun to see what a chip and a intake does!
    Apr 2006
    Houston, TX
    Only bad thing about that is you will get to 115 even faster. Just putting in a jet chip doesnt do anything to the speed limiter. The only way to get that taken off is with a B&G flash. Which is about $200 more expensive and requires taking out the whole computer.
