Originally Posted by
67alecto
Everything I've ever read about this issue (did a lot a few years ago since I was sure an Intrepid was going to be our next car) said that the sludge build up was from people stretching out the recommended oil change intervals to fit with what they felt they should get - that is, 5k miles instead of 3k miles.
There are a lot of used SEs and base 300s for sale because that is the engine of choice for rental cars. Check out some of those SEs' odometers and they'll be 20-30k I bet.
That's pretty much correct, they went to many miles between the oil changes. But the real problem was no one was using a proper oil designed for the engine, most of the common used oils that were high shear strength enough for the chain & sprocket DOHC was too thick to flow properly through the oil returns. All auto engines mfg after Jan '97 had had their oil return lines made smaller due to EPA mandate, on some engines that ran a higher head temp then other engines suffered greatly from sludge build up because they could not flow the oil fast enough to keep oil cool.
The way Chrysler cured the problem eventully was to change to 5w oil and larger oil sumps. The car will not sludge if a oil with high temp high shear strength is used that is thin enough for proper flow and has propper additive package for keeping the engine clean.
A non synthetic oil that will keep sludge from building, with high heat shear strenght for the chain & sprocket in a 0w or 5w as far as I know does not exist. That does not mean one doesen't, I just haven't checked to see. A synthetic oil like Mobil 1 0w-40 (there are other brands, but this is oil easier found then most others) will meet the high temp shear strength, viscosity needed, with proper additive package to keep soot (which forms sludge) in suspension and keep the engine clean. The Mobil 1 0w-40 can easy do 6,000 mile oil change in these engines, unless it's driven like a NYC taxi cab. I have mine on that OCI and don't expect any problems, but to be safe I will do an oil sample test at the 20,000 mile mark and let all know the results here at the forum.
Lead, follow, or get the hell out of the way.
'05 MB E320 CDI Alpine White, mine 145 MPH+ & 37 MPG
'91 MB 300D 2.5L Turbo, wife's 117 MPH & 33 MPG
