Results 1 to 15 of 19
    Reeg's Avatar
    Reeg is offline www.ChecktheBlog.net
    FrozenNorth MN
    2.7 Oil Question
    Usually I get my oil changes done @ Valvoline cause I'm lazy and don't want to do it myself. Since I've had my Magnum I've used 5W-30 Durablend, which I believe is a synthetic oil.
    Would it be harmful to my engine to switch from a synthetic oil to a regular oil? I was thinkin instead of payin Valvoline the $60+ it takes to do their oil change, I'd just spend $20 at the dealership or do it myself.
    Any advice on oil care for my car would be much appreciated.
    And is it true you REALLY need to get it changed every 3,000?
    Thanks
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    you can make the switch, but most won't recommend it. the best thing for your motor is stick with one brand of oil throughout the life of the motor.....maybe you can buy the oil and take it to them for them to do the change. that's what i do....I go buy my mobil 5/20 and filter and take it to the same shop to get it done....only because I don't have any ramps and I have known the manager for about 10 years now. My 7 qt oil change costs me about 50 bucks when it's all done.
    as far as 3000 miles, not necessarily. synthetics don't break down like conventional oils so you can do extended changes on synthetic. it also depends on your type of driving, if you drive some highway, some city and don't have much stop and go then you're ok to go extended.....if you drive a lot of stop and go, dirty dusty roads, or a lot of redline driving you need to change more often.
    Reeg's Avatar
    FrozenNorth MN
    Thanks for the input! That helps a lot!
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    Check out your Walmart. Here they stock Mobil 1, Castrol Syntec, and a few others plus the Mopar filters. As far as oil change intervals, if your using a full synthetic oil, you can go longer. I go 5,000 miles with Mobil 1 in both of my hemis. I think Mobil 1 is about $22 for a 5 qt jug at Walmart and the filter less than $4. If you do it yourself, you will know it was done right! I think your car is worth the best oil. I look on it like nobody can predict the future, if times get hard, I may have to drive my vehicles a long time.
    NC-SXT's Avatar
    NC Coast
    Not a problem to switch but that duablend is a mix anyway. Its not a full Synthetic.
    WWW.DodgeMagnumGrille.com
    Reeg's Avatar
    FrozenNorth MN
    So should I go full synthetic or stay with the DuraBlend and would that have any affect on my engine? Cause I'll switch to full synthetic today.
    Daniel454's Avatar
    Daniel454 is offline MAG V
    Nov 2005
    Union Grove, AL
    Switching to SYnthetic will not have a negative effect on your engine. In MANY cases you will actually see a gas mileage improvement (more so on the 5.7 w/MDS, dont know about the 2.7)...
    2005 Dodge Magnum AWD R/T (MINE) - MySpace Profile
    2006 Chrysler 300C SRT8 (Wife's)
    Jimsmag06's Avatar
    Jimsmag06 is offline Is now an 07 SXT!
    Patterson,Ca
    I use Amsoil Series 2000 0w-30 on my 2.7, with the amsoil filter.....I change my oil every 25000 miles, allthough, it says I can go to 35000...
    Thi filter gets changed every 6 months or 12,500 miles.
    It costs me around $55 to do a Full drain oil change, But I do it alot less often and in the long run, saves me a bit of money compared to using run of the mill oils. I get a Little bit better mileage by using the Amsoil as well, and theres alot less wear on the internals.
    Jim
    RodneyUSAF is offline KISS Keep It Simple Stupid
    Oxford, United Kingdom
    Is that a Typo? Did you mean 2500 miles? 25000 seems an awful lot.
    Reeg's Avatar
    FrozenNorth MN
    That's what I was gonna say.
    thelastgoodbrother is online now Code name: Colossus
    May 2006
    Mount Vernon, NY
    Is anyone running the royal purple oil. They are advertised as freeing up horsepower...yadayada. Lord knows the 2.7 needs all the hp we can get.
    BONE STOCK
    Jun 2006
    Houston, TX
    Quote Originally Posted by thelastgoodbrother View Post
    I did my first two oil changes but got some leaks around the breather tube....royal purple is known for this, it will find every leak you have, not a problem, just a nuisance. Power....I don't know, been using Mobil 5/20 for 10k miles now....did fine on the dyno and track for me.
    charger555's Avatar
    charger555 is offline LX Newbie
    San Diego
    Mobile 1 5/20 syn for me. great stuff
    pigpen's Avatar
    Minnesota
    0w-40 Great stuff search for oil you will find a bunch of threads
    Jimsmag06's Avatar
    Patterson,Ca
    Quote Originally Posted by RodneyUSAF View Post
    yep..25 Thousand miles. My my 1986 Suburban has almost 300 Thousand miles on her, and has used nothin but amsoil. I change that oil every 25 Thousand also.... Replace an oil pan gasket last summer...oil pan is very clean inside, no sludge!
