Results 1 to 12 of 12
    Dimon's Avatar
    Dimon is offline LX Padiwan
    Dec 2007
    Odessa, Ukraine
    Question 2.7 - 5W-30 instead of 5W-20
    Hello everybody,
    Today I have made my first maintenance service (4600 km, about four months of use already). But they have filled my engine with 5W-30 oil instead of 5W-20 that is recommended for 2.7 engines. They said it is normal to do that and this oil is also suitable for this engine. What do you think about it?
    If I throw a dog a bone, I dont want to know if it tastes good or not...
    Samoan Tsunami is offline LX Padiwan
    Jul 2007
    Tofiga Island
    this is directly from page 0-6 in the LX shop manual.
    ²
    Association des Constructeurs Européens d’ Automobiles (European Automobile Manufacturers Association)
    (ACEA)
    API SERVICE GRADE CERTIFIED
    Use an engine oil that is API Certified. Mopar
    T provides
    engine oils, meeting Material Standard
    MS-6395, that meet or exceed this requirement.
    SAE VISCOSITY
    SAE 5W-30 engine oils are recomended for the
    2.7L and 3.5L engines, for all operating temperatures.
    These engine oils improve low temperature
    starting and vehicle fuel economy. The recommended
    engine oil viscosity for vehicles equipped
    with the 5.7L engine is SAE 5W-20. Vehicles with
    5.7L engines equipped with Multiple Displacement
    System (MDS) must use SAE 5W-20 oil. Failure to
    do so may result in improper operation of the Multiple
    Displacement System (MDS). Refer to Multi
    Displacement System under Starting and Operating
    for details. Refer to the engine oil filler cap for
    the recommened engine oil viscosity for each
    vehicle. An SAE viscosity grade is used to specify the
    viscosity of engine oil. Use only engine oils with multiple viscosities such as 5W-20 or 5W-30. These are specified
    with a dual SAE viscosity grade which indicates the cold-to-hot temperature viscosity range.
    NOTE: For 5.7L INTERNATIONAL APPLICATIONS ONLY: SAE 5W30 may be substituted for the recommended
    SAE 5W20 if the 5W20 viscosity is not available in the region.
    NOTE: For 6.1L only Use API rated SL/CF full synthetic
    engine oil, such as Mobil 1T. SAE 0W-40 is
    recommended. Refer to the engine oil viscosity
    chart for the correct SAE grade meeting
    DaimlerChrysler Material Standard MS-10725.
    ACEA Categories
    For countries that use the ACEA European Oil Categories for Service Fill Oils, use engine oils that meet the requirements
    of ACEA A1/B1, A2/B2, or A3/B3.
    ENERGY CONSERVING OIL
    An Energy Conserving type oil is recommended for gasoline engines. The designation of ENERGY CONSERVING
    is located on the label of an engine oil container.
    LUBRICATION AND MAINTENANCE
    LX
    although in my owners manual for the 3.5L it says 10w-30.....
    if you got it done at a dodge dealer, then if they say ok, i'd go with it...
    since my first oil change i've used 10W-30 in the 3.5L, but 5w 30, i'll prob go with that from now on....a bit more easier to find in Royal Purple.
    Why sit around and watch everyone else live YOUR dream? Plus how many 330lb Samoans do you see doing standing dropkicks?
    NC-SXT's Avatar
    NC Coast
    You will be ok with 5w30 in the 2.7. Actualy some of the early builds had 5w30 stamped in the manual and on the cap.
    WWW.DodgeMagnumGrille.com
    Dimon's Avatar
    Dec 2007
    Odessa, Ukraine
    Alright friends, thanks for info. Now I know that it will do nothing bad to my car.
    hawk25 is offline LX Newbie
    Hey its a 2.7 if it calls for 5w-20 put that in there. There is a reason for it!!! Go get your oil changed right now to 5w-20
    Dimon's Avatar
    Dec 2007
    Odessa, Ukraine
    Quote Originally Posted by hawk25 View Post
    I was thinking about it already. Perhaps I will.
    fnkychkn's Avatar
    greasy cardboard box
    older versions of the 2.7L were using 5W30. i believe the only reason they switched to 5W20 was to boost fuel economy. they did the same with the 3.3/3.8L used in caravans.
    Warlock's Avatar
    Warlock is offline not a vendor here anymore
    Grand Junction, Colorado
    SAE VISCOSITY
    Did I miss something?
    right out of the book it says 5w30 is recomended
    Dimon's Avatar
    Dec 2007
    Odessa, Ukraine
    Quote Originally Posted by 77Warlock View Post
    SAE VISCOSITY
    Funny thing I found out is that different types of oil are recommended in different Chrysler 300 manuals. Some of them say 5W-30 only for 3.5 when 5W-20 for 2.5, 5.7, others say 5W-30 even for 2.7. On my engine's cap 5W-20 is recommended.
    Jul 2007
    Tofiga Island
    Quote Originally Posted by Dimon View Post
    bingo....
    warlock, not really missing anything, its just the chrysler is a bit
    "scattered" when it comes to info.
    MooNDoGGie's Avatar
    MooNDoGGie is offline Absent From Malaise
    Cambridge, Ontario
    My manual says 10-30 or 5-30. I use 5-30 in winter and 10-30 in summer.
    ____°º©Mo0NDoGGie©º°
    PERFORMANCE MODs: kw coilovers,zoomers exhaust,jba shortie headers,diablo predator,hammer h.o.CAI,power slot rotors,hawk pads
    COSMETIC MODS: 20" zinik's,msrt8 front fascia,colour matched fog light bezels & rear wing,shaved front badge,6000k HID headlights & foglights,shaved & debadged,tinted FOG tail lights
    INTERIOR MODS: nav radio,msrt8 kicker sub-woofer,T-handle shifter knob & leather boot,BT aluminum dash knobs
    jmckenzie's Avatar
    jmckenzie is online now LX Guru
    Jul 2007
    Lowell, MA
    i saw that the manual recommends 5w30 for V6 engines. I have a 3.5L V6 in my Charger that has 10w30 stamped on the oil cap under the hood, but the dealership has been using 5w30 every time they change my oil & I haven't had any trouble, so it must be fine to use it.
