Hi Guys!!
I hope you're OK.
I'm still a little bit confused. First off - I will most likely be buying Toyo Proxes 4 tires to replace the F1 Supercar tires. That said.... I want to be able to rotate - so all four tires have to be the same size. [Obviously] I'm torn between getting 245's, 255's or 275's. Most of you seem to say that 275's fit fine - they look great and there is NO RUBBING problems. Would that also true for 255's all around?! I ask - because the 255's are 'taller' than either the 245's OR 275's. It should be noted that the 245's on the car now DO rub a little when I'm backing up with the wheels turned all the way to the 'right'.
Also.....
Are there any negatives to having 275's? Would they be noisier than either of the two narrower sizes? Would they be less effective in light snow? Would tires that wide put an extra burden on any of the cars parts - suspension, steering, steering pump, etc.
Also.....
According to the Toyo Proxes 4 pamplet I have - the 255's and the 275's are 'reinforced'. The 245's are not. What does that mean?!
Thanks,
Craig!!![]()
